[Qgis-user] kmz in qgis
Noli Sicad nsicad at gmail.com
Wed Jan 13 03:02:41 PST 2010
Yes, it works. I tested it in QGIS. You also use Winrar to open
renamed zip file.
Noli
On 1/13/10, Agustin Lobo <alobolistas at gmail.com> wrote:
> I've found the following solution that works with my fiel, not sure
> if it would work in general:
> 1. Uncompress as if the *.kmz file were a compressed file (may be you
> have to rename it to *.zip in windows). You'll get a *.kml file
> 2. Open the *.kml file with Qgis
> Hope this work for other people as well.
> Agus
> maning sambale wrote:
>> No it's not.
>> kmz as well as kmls containing a mixture of placemarks, lines and
>> polygons.  In order to load kmls in QGIS or use ogr, you should create
>> separate files for each vector type.
>> hope that helps.
>> On Wed, Jan 13, 2010 at 5:25 PM, Agustin Lobo <alobolistas at gmail.com>
>> wrote:
>>> Is not possible to open a kmz file in qgis?
>>> or am I not seeing an obvious option?
>>> I've tried with OGR converter also.
>>> Thanks
>>> Agus
>>> Qgis-user mailing list
>>> Qgis-user at lists.osgeo.org
>>> http://lists.osgeo.org/mailman/listinfo/qgis-user
