[Qgis-user] Cannot open / convert any KML in QGIS ? (OGR)
Jeremy G-2
jeremy.grx at gmail.com
Wed Jan 13 06:36:07 PST 2010
Hi Mario,
Thanks for your answer.
(I'm replying on Nabble because I couldn't see your answer on the list,
don't know what's going on)
I tried to access my KML files from the converter but it highlighted another
bug (!). I can't figure out how to display the files in the directory. I
screenshot the issue with the plugin window on the left and the file
explorer on the right side. When I click on the file type dialog (where the
mouse is on the picture - are you still following ? ;) ), I don't have any
choice of type - just "OGR file datasource"(1) - and cannot see any file
even if I know there are KML files present in the directory (Kml or Shp, the
issue is the same).
I'm running QGIS 1.4 on Ubuntu Karmic.
Any help welcome ! Thanks,
Jeremy
(1) http://www.geographiques.org/img/QGIS-pb-OGR.png
Mario Q wrote:
> Hey,
> It does fail with the 'add layer' menu, but it works fine for me with the
> plugin OGR converter.
> Best,
> Mario
> Jeremy G-2 wrote:
>> Hi list,
>> I'm trying to read / write a couple of KML files that I created in Google
>> Maps. It doesn't even open the files and says "Invalid data source".
>> Is there a known limitation of KML from Google Maps/Earth with OGR ?
>> Thanks a lot,
>> Jeremy
>> Qgis-user mailing list
>> http://lists.osgeo.org/mailman/listinfo/qgis-user
View this message in context: http://n2.nabble.com/Cannot-open-convert-any-KML-in-QGIS-OGR-tp4293302p4348880.html
Sent from the qgis-user mailing list archive at Nabble.com.
