[Qgis-user] build virtual raster
Giovanni Manghi giovanni.manghi at gmail.com
Fri Jan 15 08:12:13 PST 2010
works fine here (version 0.0.31) and xp.
Looking the error message it seems you miss the gdal utilities or you
miss to add the path to the utilities bin directory in the "path"
environment variable of your os.
cheers
-- Giovanni --
On Fri, 2010-01-15 at 16:50 +0100, marcozanieri at geosweb.it wrote:
> hi, i want to report an error in tool gdal using "build
> virtual raster", when i try to use this tool appears the
> error:
> Traceback (most recent call last):
>   File "C:\Documents and
> Settings\marco\.qgis\python\plugins\GdalTools\tools\dialogBase.py"
> , line 85, in processError
>     msg = QString.tr("The process failed to start. Either
> the invoked program is missing, or you may have insufficient
> permissions to invoke the program.")
> AttributeError: type object 'QString' has no attribute 'tr'
> The S.O. is winxp.
> marco zanieri
> Qgis-user mailing list
