[Qgis-user] qgis1.4.0-2 on MAC crashes
=?ISO-8859-1?Q?Ant=F3nio_M?=. Rodrigues
amrodrigues at fcsh.unl.pt
Fri Jan 15 10:15:02 PST 2010
Problem solved.
Had to update the PROJ framework.
Thanks.
(from log...)
Date/Time: 2010-01-15 17:57:06.775 +0000
OS Version: Mac OS X 10.5.8 (9L31a)
Report Version: 6
Anonymous UUID: 2A812FAD-01FD-48E4-948F-48579DBA5CC7
Exception Type: EXC_BREAKPOINT (SIGTRAP)
Exception Codes: 0x0000000000000002, 0x0000000000000000
Crashed Thread: 0
Dyld Error Message:
Library not loaded: /Library/Frameworks/PROJ.framework/Versions/4/PROJ
Referenced from: /Volumes/Qgis-Leopard/Qgis.app/Contents/MacOS/Qgis
Reason: image not found
On Fri, 15 Jan 2010 11:14:31 -0600, William Kyngesburye wrote
> Which system version? Did you install the Qgis version that matches
> your system?
> No need to start from scratch. Open Console.app and look in your
> home crashlogs for a Qgis crashlog. This will help determine what's
> wrong.
> On Jan 15, 2010, at 10:54 AM, António M. Rodrigues wrote:
> > Hi.
> > I downloaded today QGIS1.4.0-2 for MAC OS from kyngchaos.com (installed all necessary
frameworks
> > first).
> > When launching it instantly crashes.
> > I'm not sure it is related to older installations. How can I trash everything (really everything)
related to
> > qgis (and by the way GRASS, since I will need GRASS support from QGIS) in order to really start
from
> > scratch.
> > Thanks in advance.
> > António
> > Qgis-user mailing list
> > Qgis-user at lists.osgeo.org
> > http://lists.osgeo.org/mailman/listinfo/qgis-user
> William Kyngesburye <kyngchaos*at*kyngchaos*dot*com>
> http://www.kyngchaos.com/
> Earth: "Mostly harmless"
> - revised entry in the HitchHiker's Guide to the Galaxy
