[Qgis-user] fill patterns in map printing
Marco Hugentobler marco at hugis.net
Wed Jan 20 02:13:03 PST 2010
Hi Markus
In the newest svn trunk version, there is an svg fill renderer that scales an
svg pattern to the resolution of the screen / composer. Like this, you could
create a line texture as svg file, e.g. in inkscape (or ask on the list if
someone already has a good one). Then, in the vector prop. dialog, click 'new
symbology', click 'properties' and choose symbol layer type 'SVGFill'.
The brush scaling does not work if you print to pdf (due to a known bug in the
Qt library). But it is supposed to work for direct printing, postscript, svg
or to a pixel graphic format (e.g. jpg, png).
Regards,
Marco
Am Mittwoch, 20. Januar 2010 10.30:03 schrieb Markus Nater:
> nobody any advice how to print out a map with line fill patterns that
> are not too thin? (to visualize two layers that are above each other)
> I am desperate, should hand in some maps and can't get over this
> obstacle... so I probably will have to rebuild all my projects in
> arcview just in order to print out a decent map...!
> cheers
> mark
> Qgis-user mailing list
Dr. Marco Hugentobler
HUGIS - GIS programming and consulting
Webereistrasse 66
CH-8134 Adliswil
marco at hugis.net
http://homepage.hispeed.ch/hugis
Technical Advisor QGIS Project Steering Committee
