[Qgis-user] [QGIS-LIST] Contour plugin install under OSGEO4W -follow-up
Benoit de Cabissole cabi at mweb.co.za
Wed Jan 20 07:25:31 PST 2010
Hi Jurgen,
Jürgen E. Fischer wrote:
> Hi Benoit,
> On Wed, 20. Jan 2010 at 10:51:41 +0200, Benoit de Cabissole wrote:
> > -> all is fine, shapefile is created but it is not loaded.
> >    Module issues the following error:
> > ERROR 1: Can't load requested DLL:
> C:\PROGRAMS\OSGeo4W\apps\gdal-16\bin\gdalplugins\gdal_ECW_JP2ECW.dll 126:
> > The specified module could not be found. ERROR 1: Can't load
> requested DLL:
> Did you install the third party DLLs?  See [1]
Not specifically for verion QGIS 1.4 from OSGEO4W. I've installed those dlls
long ago for QGIS 1.0.x standalone and never removed them from the system.
In QGIS 1.4 I can open MrSID file with no problems. But opening ecw & jp2
files has problems.
So I copied those 4 dlls to the OSGeo4W\bin folder and, miracle, everything
is working fine:
- opening of ecw and jp2 files does not have problems anymore...
- contour from the raster menu (gdal) does not complain anymore...
Jürgen, you're a star. Many thanks.
Warning for other OSGEO4W users:
On a new installation of OSGEO4W, please copy the 4 dlls from ERMapper SDK
into the OSGEO4W bin folder. Even if the SDK has been previously installed,
OSGEO4W QGIS will not be able to correctly use the installed dlls.
Benoit
> Jürgen
> [1]
http://www.qgis.org/wiki/OSGeo4wSetup#Installing_support_for_raster__.2A.ECW
_.28ERMapper.29_and_.2A.sid_.28MrSid.29_formats
