[Qgis-user] Re: Qgis-user Digest, Vol 47, Issue 62
mtnbiketrail at zzz.com mtnbiketrail at zzz.com
Sat Jan 30 09:13:22 PST 2010
I want users to annotate landform data, such as trees, rocks, water, that is too detailed to be found on a topo map. I want to be able to create a QR on-the-fly depending on what area of the map the user selected. Again, look at walking-papers.org
Tom
essage: 6
Date: Fri, 29 Jan 2010 10:37:42 +0800
From: maning sambale <emmanuel.sambale at gmail.com>
Subject: Re: [Qgis-user] Re: QR barcodes
To: qgis-user at lists.osgeo.org
Message-ID:
	<f902f9841001281837pa404820u8c290ba03aa5a260 at mail.gmail.com>
Content-Type: text/plain; charset=UTF-8
Just curious, for what purpose?  I am aware of how qr codes are used
in virtually anything in japan.
I want to create a similar inventory system for our printed map.
On Fri, Jan 29, 2010 at 3:40 AM, Alex Mandel <tech_dev at wildintellect.com> wrote:
> > mtnbiketrail at zzz.com wrote:
>> >> I saw the walking-papers.org website. Here is my question:
>> >> Can anyone point me in the direction on how this would be done inside
>> >> QGIS? How would I generate a QR code for a printed map made from inside
>> >> QGIS. Or does it only work with certain map programs? The QR barcode
>> >> generators I found seem to be stand alone programs.
>> >> thanks,
>> >> Tom
> > Sure you'll need to find an open source library for encoding the
> > barcodes. One example might be http://qrcode.sourceforge.jp/
> > Then you can write a qgis plugin that integrates into the app. Basically
> > a prompt that asks for the information need to create the barcode and
> > then places the results on the map composer or map window (kinda like
> > the north arrow).
> > Note you could cheat for now and create it oustide the app and make it a
> > north arrow or just drop it on top of the final map.
> > Alex
