[Qgis-user] Contour Plugin installation on QGIS 1.4
badaveil
badaveil at gmail.com
Thu Jan 28 02:24:22 EST 2010
Hi
I am sharing my experience on the installation of the above on an Ubuntu and
Windows platform:
Ubuntu 9.10
1. Contour plugin won't install, requires matplotlib
2. Lionel Roubeyrie (Thank you) recommends terminal command "sudo apt-get
install python-matplotlib"
3. Matplotib installed but contour plugin won't install, requires shapely
4. Copied earlier command but placed "matplotlib" with "shapely" (Guess
work)
4. Shapely installed, activated QGIS
5. Select Plugins/fetch plugins/select contour plugin/OK
6. Contour plug installed at last!
Windows XP
2. Matplotlib won't install, requires python >2.2
3. Installed python 2.6.4, Matplotlib 0.99 installed
4. Contour plugin won't install, requires shapely
5. Shapely 1.0.14 installed, Contour plugin still won't install
6. Give up.(I'm no programmer)
Abbas Abdul Wahab
http://badaveil.multiply.com
URL: http://lists.osgeo.org/pipermail/qgis-user/attachments/20100128/679a054e/attachment.html
