[Qgis-user] (no subject)
Lionel Roubeyrie lionel.roubeyrie at gmail.com
Mon Jul 26 10:23:38 EDT 2010
Hi Guiseppe,
ok no polemic no troll (and no woman no cry :p ) just sometimes is
good to look at the basics.
For the message, effectively the Python plugin installer normally
catches the error, then what about the first Herman problem
"ImportError: No module named owslib.etree"?
Is it possible to think about having a small dialog for each plugin in
the installer where plugins devs could set some more detailled
description and maybe the dependencies?
My 2 cents
2010/7/26 Giuseppe Sucameli <brush.tyler at gmail.com>:
> Hi Lionel,
> On Mon, Jul 26, 2010 at 1:43 PM, Lionel Roubeyrie
> <lionel.roubeyrie at gmail.com> wrote:
>> Hi all,
>> it's not an abnormal plugin fonctionnality but a standard error
>> message saying there's some python unsatisfied dependencies, like you
>> can read at the end of the error message or from the shell :
>> "ImportError: No module named matplotlib.pyplot". Just have to install
>> matplotlib and all will be ok.
> AFAIK normally that exception is intecepted by the Python Plugin Installer
> that shows the unsatisfied dependencies.
> Did you try what happens with other plugins?
> AFAICS no error message is shown by the other plugins with
> unfulfilled dependencies.
>> After that, when I was young I learned
>> a basic rule of life saying if I want an information, I have to
>> correctly ask the question and not so optionnaly be civilized with an
>> simple "hello". Didn't see that in the first post...
> I agree, but it's better to avoid unnecessary polemics.
> Shortly before starting this thread, Herman write another thread
> titled "what happens?.." that starts:
> "hi tim and qgis users".
> So I think that it's only a blunder, nobody would start a thread
> without subject and greeting.
> Cheers.
>> > Hi Noli,
>> > the Python Plugin Installer shows the unsatisfied dependencies yet.
>> > After the error message you should see the "Error loading plugin"
>> > dialog which says to you there are unfulfilled dependencies.
>> > Instead it's strange to see the error message!
>> > Trying to install other plugin with unsatisfied dependencies I don't
>> > see it, but the "error loading plugin" dialog only.
>> > So it's an abnormal plugin behaviour.
>> > Cheers.
>> > Hi Noli,
>> > Cheers.
>> > On Mon, Jul 26, 2010 at 3:08 AM, Noli Sicad <nsicad at gmail.com> wrote:
>> >> I think this problem is very typical problem for plugins with
>> >> dependencies with other python packages.
>> >> It would have been better if plugins would show the dependecies
>> >> message so user could download and install the package.
>> >> In this case, just tell the user to download and install the matplotlib
>> >> package.
>> >> http://matplotlib.sourceforge.net/users/installing.html
>> >> Noli
>> >> On 7/26/10, Carson Farmer <carson.farmer at gmail.com> wrote:
>> >> > Except that will remove all plugins! What you probably really want
>> >> > is:
>> >> > rm -rf /Users/hermanpalaquium/.qgis/python/plugins/contour
>> >> > Which will only remove the contour plugin, which is failing to load
>> >> > because matplotlib isn't installed...
>> >> > I think you can also do this from the Python plugin installer by
>> >> > selecting to remove the plugin?
>> >> > Carson
>> >> >> Traceback (most recent call last):
>> >> >>   File
>> >> >> "/Applications/Qgis.app/Contents/MacOS/../Resources/python/qgis/utils.py",
>> >> >> line 119, in loadPlugin
>> >> >>     __import__(packageName)
>> >> >>   File
>> >> >> "/Users/hermanpalaquium/.qgis//python/plugins/contour/__init__.py",
>> >> >> line 28, in
>> >> >>     from contour import Contour
>> >> >>   File
>> >> >> "/Users/hermanpalaquium/.qgis//python/plugins/contour/contour.py",
>> >> >> line 38, in
>> >> >>     import matplotlib.pyplot as plt
>> >> > Carson J. Q. Farmer
>> >> > ISSP Doctoral Fellow
>> >> > National Centre for Geocomputation
>> >> > National University of Ireland, Maynooth,
>> >> > http://www.carsonfarmer.com/
>> >> > _______________________________________________
>> >> > Qgis-user mailing list
>> >> > Qgis-user at lists.osgeo.org
>> >> > http://lists.osgeo.org/mailman/listinfo/qgis-user
>> > Giuseppe Sucameli
>> Lionel Roubeyrie
>> http://youarealegend.blogspot.com
> Giuseppe Sucameli
Lionel Roubeyrie
