[Qgis-user] Points2one - group by input field
Goyo goyodiaz at gmail.com
Sat Jun 5 12:00:00 PDT 2010
Hello Jean,
El vie, 04-06-2010 a las 14:47 +0200, MORREALE Jean Roc escribió:
> Hi,
> As pointed in another thread I'm using Points2One on the output of a tacheometer to connect automagically the survey points. Recently has been added the possibility to group the features using an input field, my problem is that it only groups these features if the chosen input field's values are strictly sequential : if a feature B is between two sequences of the feature A then those 2 sequences become 2 different polygons instead of one (A:1/2/3, B:3/4/5, A:6/7/8 instead of A:1/2/3/6/7/8).
> PT    X     Y     Z    CD
> 1   0996  515  8,2   A
> 2   0998  515  8,2   A
> 3   1009  504  8,2   B
> 4   1010  504  8,2   B
> 5   1010  504  8,2   B
> 6   0996  515  8,2   A
> 7   0998  515  8,2   A
> 8   0999  515  8,2   A
> It would be great if the plugin could parse the file, group the feature points sequentially by the input field and only then draw the polygon as it would allows a surveyer to stop collecting a long feature to collect a small nearby feature and then resume on the previous one.
Please install version 0.2.2 of the plugin and see if it does what you
need. It allows you to sort the points by the grouping attribute. You'll
find it in the plugin installer.
Regards
Goyo
