[Qgis-user] qgis installation
Ivan Mincik
ivan.mincik at gista.sk
Wed Jun 9 06:13:53 PDT 2010
On Wednesday 09 June 2010, Mohammed Rashad wrote:
> this is my qgis cmake . log output
> -- Found Proj: /usr/lib/libproj.so
> -- Found Expat: /usr/lib/libexpat.so
> -- Using GSL from /usr
> -- Found GEOS: /usr/lib/libgeos_c.so
> -- Found GDAL: /usr/local/lib/libgdal.so
> -- Found PostgreSQL: /usr/lib/libpq.so
> -- Found GRASS: /usr/local/grass-6.5.svn (6.5.svn)
> -- Python libraries found
> -- SIP is required in version 4.7 or later!
> -- Python bindings disabled due dependency problems!
Python bindings disabled because of old sip version ?
> -- Pedantic compiler settings enabled
> -- Python not being built
> -- Configuring done
> -- Generating done
> -- Build files have been written to: /home/rashad/qgis
> is there any problem in this configuration
> Rashad
Ivan Mincik
