[Qgis-user] Custom CRS in PROJCS
Agustin Lobo
alobolistas at gmail.com
Fri Jun 11 09:14:21 PDT 2010
Hi!
The projection of the DEM of Europe
http://www.eea.europa.eu/data-and-maps/data/digital-elevation-model-of-europe
is defined as
PROJCS["User_Defined_Lambert_Azimuthal_Equal_Area",GEOGCS["GCS_User_Defined",DATUM["D_User_Defined",SPHEROID["User_Defined_Spheroid",6378137.0,0.0]],PRIMEM["Greenwich",0.0],UNIT["Degree",0.0174532925199433]],PROJECTION["Lambert_Azimuthal_Equal_Area"],PARAMETER["False_Easting",5071000.0],PARAMETER["False_Northing",3210000.0],PARAMETER["Central_Meridian",20.0],PARAMETER["Latitude_Of_Origin",52.0],UNIT["Meter",1.0]]
How can this be translated into the proj4 syntax that can be use in
QGIS to define
a Custom CRS?
Thanks
Agus
