[Qgis-user] multiple lines label not working
maning sambale
emmanuel.sambale at gmail.com
Mon Jun 28 05:19:17 PDT 2010
excellent! two new cool tip in a day
Thanks!
On Mon, Jun 28, 2010 at 7:19 PM, Jürgen E. <jef at norbit.de> wrote:
> Hi Maning,
> On Mon, 28. Jun 2010 at 18:27:11 +0800, maning sambale wrote:
>> In the layer properties labels tab, there is an option for
>> multiplelines labels. I added "/n" into the label name attribute then
>> activated the multiplelines option.
> You have to enter a "real" newline. If you want to enter multiline labels in
> QGIS you need to assign a TextEdit instead of LineEdit as edit widget in the
> vector layer properties' attributes tab.
> Jürgen
> Jürgen E. Fischer norBIT GmbH Tel. +49-4931-918175-20
> Dipl.-Inf. (FH) Rheinstraße 13 Fax. +49-4931-918175-50
> Software Engineer D-26506 Norden http://www.norbit.de
> norBIT Gesellschaft fuer Unternehmensberatung und Informationssysteme mbH
> Rheinstrasse 13, 26506 Norden
> GF: Jelto Buurman, HR: Amtsgericht Emden, HRB 5502
> Qgis-user mailing list
cheers,
maning
"Freedom is still the most radical idea of all" -N.Branden
wiki: http://esambale.wikispaces.com/
blog: http://epsg4253.wordpress.com/
