[Qgis-user] Segmentation fault...
Luigi Castro Cardeles luigi.cardeles at gmail.com
Mon Mar 1 08:23:09 PST 2010
Hi list,
maybe there are other problem (relate to pyqgis):
Não foi possível carregar PyQGIS.
Suporte à Python vai ser desabilitado.
  File "", line 1, in
RuntimeError: the sip module implements API v7.0 but the qgis.core module
requires API v6.0
Versão do Python:
2.6.2 (r262:71600, Aug 21 2009, 12:23:57)
[GCC 4.4.1 20090818 (Red Hat 4.4.1-6)]
Caminho para o Python:
['/usr/local/share/qgis/python', '/home/luigi/.qgis//python',
'/home/luigi/.qgis//python/plugins', '/usr/local/share/qgis/python/plugins',
'/usr/lib64/python26.zip', '/usr/lib64/python2.6',
'/usr/lib64/python2.6/plat-linux2', '/usr/lib64/python2.6/lib-tk',
'/usr/lib64/python2.6/lib-old', '/usr/lib64/python2.6/lib-dynload',
'/usr/lib64/python2.6/site-packages',
'/usr/lib64/python2.6/site-packages/PIL',
'/usr/lib64/python2.6/site-packages/gst-0.10',
'/usr/lib64/python2.6/site-packages/gtk-2.0',
'/usr/lib64/python2.6/site-packages/webkit-1.0',
'/usr/lib64/python2.6/site-packages/wx-2.8-gtk2-unicode',
'/usr/lib/python2.6/site-packages']
QGIS start but without python.
I only run the version i have installed.
[]'s
2010/3/1 Pedro Tarroso <ptarroso at mail.icav.up.pt>
>  Hi
> Thank you all for the answers (obrigado Giovanni!). I think what happened
> is the same thing that Micha describes. It was the last week (and I suppose
> after that upgrade) that the software begun to give the seg fault. I don't
> have the xfce installed but I will try to have a look to it.
> Cheers,
> Pedro
> -----Original Message-----
> From: Micha Silver [mailto:micha at arava.co.il <micha at arava.co.il>]
> Sent: Mon 3/1/2010 3:25 PM
> To: Pedro Tarroso
> Cc: qgis-user at lists.osgeo.org
> Subject: Re: [Qgis-user] Segmentation fault...
> On 03/01/2010 03:26 PM, Pedro Tarroso wrote:
> > Hi
> > I'm trying to use QGIS 1.0.2 on a Fedora 11 machine but I get all the
> > time a Segmentation Fault error...  I have looked in some forums for
> > similar problems and there was a common problem about Qt. However, I
> > already tried the Qt config without success. The strange behaviour is
> > that QGIS runs fine as a super user! Can it be some permissions? Any
> idea?
> I found the same problem running QGIS 1.4 on Fedora 12 after a yum
> update recently (Feb 24 I think) which upgraded some qt packages. I also
> find that QGIS starts when run as super user, and in addition, if I
> switch to xfce instead of Gnome, QGIS starts fine (as a regular user).
> Can you verify that under xfce (if you have that window manager
> installed) on your setup it works?
> Thanks,
> Micha
> > Thanks!
> > Pedro
> > This mail was received via Mail-SeCure System.
> > Qgis-user mailing list
> > Qgis-user at lists.osgeo.org
> > http://lists.osgeo.org/mailman/listinfo/qgis-user
> Micha Silver
> http://www.surfaces.co.il/
> Arava Development Co.  +972-52-3665918
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20100301/ce7b486d/attachment.html>
