[Qgis-user] Segmentation fault...
Luigi Castro Cardeles luigi.cardeles at gmail.com
Mon Mar 1 08:50:23 PST 2010
Thanks Martin,
i use a compiled qgis.
For Fedora Users, i think that this update comes with kde-4.4.0 updates.
[]'s
2010/3/1 Martin Dobias <wonder.sk at gmail.com>
> On Mon, Mar 1, 2010 at 5:23 PM, Luigi Castro Cardeles
> <luigi.cardeles at gmail.com> wrote:
> > Hi list,
> > maybe there are other problem (relate to pyqgis):
> > Não foi possível carregar PyQGIS.
> > Suporte à Python vai ser desabilitado.
> > Traceback (most recent call last):
> >   File "", line 1, in
> > RuntimeError: the sip module implements API v7.0 but the qgis.core module
> > requires API v6.0
> This looks like you've updated sip package in your system, however
> qgis python module still awaits older version.
> - if you run self-compiled qgis, just recompile it and install again.
> It should adapt to newer sip version
> - if you run qgis from a distribution package, request an updated
> package from the packager
> - you could downgrade sip package and all packages that depend on it
> (PyQt, PyKDE) but I wouldn't recommend that as it might break your
> system
> Martin
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20100301/47447f1f/attachment.html>
