[Qgis-user] Custom Symbology and Inkscape
Giovanni Pasini jynxtor at gmail.com
Tue Mar 2 00:24:47 PST 2010
Il giorno Tue, 02 Mar 2010 11:18:51 +1100
Roland Hill <Roland.Hill at FourWindsTechnology.com.au> ha scritto:
> List,
> I think this is a QT issue rather than QGIS, but I thought I would
> share it to save others the hours it takes to figure it out
> (especially if you are trying new-symbology for the first time).
> There appears to be a problem using svg symbols created with Inkscape
> 0.47, whereas the same symbols created with Inkscape 0.46 work just
> fine. This is only for objects that have been converted to paths. The
> 0.47 symbols fail to render in QGIS, but also fail to render in the
> Dolphin preview pane (whereas 0.46 symbols do render in both).
See also http://forum.kde.org/viewtopic.php?f=67&t=62961
[...]	all Plasma svg rendering is dependent on Qt, and it likely
	could be an issue with QSvgRenderer
> If anyone else can confirm this, or knows of a solution, it would be
> much appreciated. I am using Kubuntu 9.10 and QGIS trunk.
	Just in case anyone else happens to come across this issue with
	Inkscape 0.47, I've managed to solve the problem by enabling
	"Force Repeat Commands" under Inkscape Preferences > SVG Output.
> Regards,
> Roland
Giovanni
> Qgis-user mailing list
