[Qgis-user] symbology Unique Value from Postgis Table
Michael Diener m.diener at gomogi.com
Wed Mar 3 00:36:56 PST 2010
Hi Mike,
Yes there are some spaces it the fields and some '-' and '_'
Field data type is:  character(33)
I did try it out on other fields and it DID   work just fine that is why I'm
stuck.
Do I need to remove all special characters and spaces?
Cheers
michael
-----Original Message-----
Sent: Montag, 01. März 2010 16:27
To: m.diener at gomogi.com
Cc: qgis-user at lists.osgeo.org
Subject: Re: [Qgis-user] symbology Unique Value from Postgis Table
Hi Michael,
Do you have any odd names (spaces or case) in your
dbname/schema/table/column/datatype? What is the data type of the
field you are attempting this with? Have you tried making a unique
classification on other fields or tables with the same unexpected
result?
-Mike
On 1 March 2010 07:08, Michael Diener <m.diener at gomogi.com> wrote:
> Hi,
> I have tried everything possible to get my postgis Polygon table to
display
> a unique value as a thematic map.  It generates the legend nicely but
won’t
> display it in the map window all polys get the default color no matter
what
> I try.
> System:  qgis 1.4 build revision 12728  Windows XP  sp 3
> KML or shp work fine using the unique value symbology
> Is this a bug or am I missing something obvious, just not obvious to me
yet.
> Cheereo
> michael
> Michael Diener
> _________________________________________________________________
> GOMOGI Mobile Geographics
> LAKESIDE PARK B01
> 9020 KLAGENFURT
> T: ++043 (0) 676 520 3600
> E: m.diener at gomogi.com
> W: www.gomogi.com
> Qgis-user mailing list
