[Qgis-user] Working with ESRI mdb geodatabase file
G. Allegri giohappy at gmail.com
Wed Mar 3 07:36:47 PST 2010
If you're working on Windows you should first create an ODBC
connection through Administrative Tools.
giovanni
2010/3/3 Werner Macho <werner.macho at gmail.com>:
> hi Piotr!
> regarding to this post
> http://www.mail-archive.com/qgis-user@lists.osgeo.org/msg00597.html
> you should be at least able to use GDAL to convert your mdb in a QGIS
> readable format..
> regards
> Werner
> Am 03.03.2010 16:28, schrieb Piotr Pachół:
>> Hello,
>> I have ESRI mdb geodatabase file.
>> How can I create a database connection to this file ?
>> When I try to use option: "Add vector layer/Create database
>> connection/ESRI Personal Geodatabase"
>> I have an error: "Unable to initialize ODBC connection to DSN"
>> So what should  fill in connection information ? (host, database, port)
>> Where I can fill in full path with name and extension of file ?
>> Piotr
>> Qgis-user mailing list
>> http://lists.osgeo.org/mailman/listinfo/qgis-user
