[Qgis-user] OTF reprojection and +towgs84 parameters
Standaert Arnout arnout.standaert at vito.be
Wed Mar 3 08:05:08 PST 2010
>-----Original Message-----
>From: Jean-Claude Repetto [mailto:jcrml at mxm.eu]
>Standaert Arnout a écrit :
>>  * set OTF projection on and project CRS to Google Mercator (EPSG 900913)
> Hello,
> EPSG 900913 is not defined in QGIS, you should try EPSG 3785
Actually, 900913 was added recently in the nightly builds. I'm using the nightly OSGEO4W builds on Windows.
> If it doesn't work, try to add the parameter "+nadgrids=@null " to the
> projection string.
What does this exactly do?
In any case, it behaves strangely in QGis: I specified a custom CRS using my Lambert proj string (with the correct +wgs84 parameters) and adding "+nadgrids=@null", but when selecting this custom CRS in "Layer properties" (via "Specify CRS"), the proj string is not updated in the Layer properties window.
Reading around, it seems both a +towgs84 and +nadgrids parameter clause in the proj string are conflicting? Is this why QGis doesn't update the proj string with the custom one?
Getting confused more and more,
Arnout
PS. My apologies for the company disclaimer below...
Uniting expertise from different fields of technology in a pleasant and stimulating environment enhances innovation and  the development of novel methods for sustainable production.
Have a look at the international congress 'Innovation for Sustainable Production 2010'
April, 18-21, 2010 - Bruges (Belgium)
http://www.i-sup2010.org
This e-mail, any attachments and the information it contains are confidential and meant only for the use of the addressee(s) only.  Access to this e-mail by anyone other than the addressee(s) is unauthorized.  If you are not the intended addressee (or responsible for delivery of the message to such person), you may not use, copy, distribute or deliver to anyone this message (or any part of its contents) or take any action in reliance on it.  In such case, you should destroy this message and notify the sender immediately.  If you have received this e-mail in error, please notify us immediately by e-mail or telephone and delete the e-mail from any computer.
All reasonable precautions have been taken to ensure no viruses are present in this e-mail and its attachments.  As our company cannot accept responsibility for any loss or damage arising from the use of this e-mail or attachments we recommend that you subject these to your virus checking procedures prior to use.
