[Qgis-user] Working with ESRI mdb geodatabase file
G. Allegri giohappy at gmail.com
Wed Mar 3 08:22:29 PST 2010
I don't know because I rearely use gdb from OS software, but I don't
think. The domains are set using relations between domain and data
tables internally the mdb, I don't think the ogr driver follow this
relations to retrieve the domain values. You could:
 - save the mdb with the substituted values, e.g. from a query where
you ask for the joined coded values <-> domains values
-  export the domains table from the mdb as dbf and use the Ftools
plugin to join it to the features attribute table.
giovanni
2010/3/3 Piotr Pachół <piotr.pachol at wodgik.katowice.pl>:
> Thanks, it is working !
> But one question: is it possible to display coded value domains which I have
> defined in mdb file ?
> Piotr
> G. Allegri pisze:
>> If you're working on Windows you should first create an ODBC
>> connection through Administrative Tools.
>> giovanni
>>  Hello,
>>>> I have ESRI mdb geodatabase file.
>>>> How can I create a database connection to this file ?
>>>> When I try to use option: "Add vector layer/Create database
>>>> connection/ESRI Personal Geodatabase"
>>>> I have an error: "Unable to initialize ODBC connection to DSN"
>>>> So what should  fill in connection information ? (host, database, port)
>>>> Where I can fill in full path with name and extension of file ?
>>>> Piotr
>>>> _______________________________________________
>>>> Qgis-user mailing list
>>>> Qgis-user at lists.osgeo.org
>>>> http://lists.osgeo.org/mailman/listinfo/qgis-user
