[Qgis-user] Segmentation fault...
Micha Silver micha at arava.co.il
Thu Mar 4 01:22:30 PST 2010
On 03/04/2010 03:43 AM, Luigi Castro Cardeles wrote:
> Hi list,
> my system:
> kernel -> 2.6.31.12-174.2.22.fc12.x86_64;
> python -> Python 2.6.2
> sip -> 4.10
> gis -> 1.4.0 revision 12996 with the path applied.
> gnome -> 2.28.2
> qt -> 4.6.2.
> some time ago, there is a configuration with qtconfig-qt4 that was
> causing to me and to others segfault. On qtconfig-qt4, GUI style , i
> have to change from default to any other style to prevent crashes.
> Did you try to do that?
I'm also still stuck with QGIS segfaulting. I find:
* It happens Only in Gnome (xfce and KDE work fine on the same machine,
with the same binary)
* When running as super user the segfault disappears.
* I tried Luigi's suggestion to change the default Qt style in
qtconfig-qt4, but I still get the same segfault...
* It started after an update to some qt packages on Feb 24.
Any ideas where to report this problem to Gnome/Qt devs?
Micha
> []'s
> 2010/3/3 David J. Bakeman <dbakeman at comcast.net
> <mailto:dbakeman at comcast.net>>
>>     Hi,
>>     Thanks Micha and Jurgen for the help. I applied the patch and
>>     compile qgis. Now it runs without error and with python.
>>     I run the app on gnome and kde (latest version) with  normail
>>     user on Fedora 12.
>     I compiled 1.4.0 on FC11 with the fix to find sip and it still
>     crashes when I use gnome even if I'm superuser.  If I use xfce on
>     the console it works but if I'm running gnome on the console and I
>     try to run qgis in a virtual screen using xfce it still crashes!
>>     []'s
>>     2010/3/2 Micha Silver <micha at arava.co.il <mailto:micha at arava.co.il>>
>>         On 03/01/2010 11:13 PM, Luigi Castro Cardeles wrote:
>>>         Hi,
>>>         i recompiled qgis 1.4.0 and keep with the same problem. QGIS
>>>         run but not python plugin, i also get the same error message
>>>         about sip version.
>>         You might want to try the patch that I received from Jurgen
>>         Fischer [1]:
>>         --- qgis-1.4.0+12730~/cmake/Python.cmake    2010-01-07
>>         11:33:11.000000000 +0100
>>         +++ qgis-1.4.0+12730/cmake/Python.cmake    2010-02-05
>>         18:02:29.000000000 +0100
>>         @@ -148,8 +148,8 @@
>>              IF (HAVE_SIP_MODULE AND SIP_BINARY_PATH AND SIP_INCLUDE_DIR)
>>                # check for SIP version
>>                # minimal version is 4.7 (to support universal builds)
>>         -      SET (SIP_MIN_VERSION 040700)
>>         -      TRY_RUN_PYTHON (RES "import sip\nprint '%x' %
>>         sip.SIP_VERSION" SIP_VERSION)
>>         +      SET (SIP_MIN_VERSION 263936) # 0x40700
>>         +      TRY_RUN_PYTHON (RES "import sip\nprint '%d' %
>>                IF (SIP_VERSION EQUAL "${SIP_MIN_VERSION}" OR
>>         SIP_VERSION GREATER "${SIP_MIN_VERSION}")
>>                  SET (SIP_IS_GOOD TRUE)
>>                ENDIF (SIP_VERSION EQUAL "${SIP_MIN_VERSION}" OR
>>         Create a new file called Python.cmake.patch in the directory
>>         where your qgis source is located then do:
>>         patch cmake/Python.cmake Python.cmake.patch
>>         Now run:
>>          cmake -L ..
>>         again from the build directory  and check that Python and SIP
>>         were found.
>>         [1]
>>         http://n2.nabble.com/Fedroa-12-and-new-version-of-qt-tc4638666.html#a4638702
>>>         When i run cmake .. and configure (c), the dialog show some
>>>         msg but it goes so fast that i can't read. There is some way
>>>         to slowdown that message or is this logged on a file? Sorry
>>>         but i don't know cmake very well.
>>>         []'s
>>>         2010/3/1 Micha Silver <micha at arava.co.il
>>>                 Thanks Martin,
>>>                 i use a compiled qgis.
>>>                 For Fedora Users, i think that this update comes
>>>                 with kde-4.4.0 updates.
>>>                 []'s
>>>             I also have a self compiled qgis 1.4.  After updating to
>>>             the new PyQt4 and sip (also updated qt and qt-x11
>>>             packages) last week, I recompiled, and still get the
>>>             segfault. And again, after switching to xfce, QGIS
>>>             starts fine. Under Gnome, QGIS will start only if run as
>>>             super user. So my guess is that the problem is some
>>>             interaction between Gnome and Qt in the newer packages.
>>>                 2010/3/1 Martin Dobias <wonder.sk <http://wonder.sk>
>>>                 <http://wonder.sk>@gmail.com <http://gmail.com>
>>>                 <http://gmail.com>>
>>>                    On Mon, Mar 1, 2010 at 5:23 PM, Luigi Castro Cardeles
>>>                 <luigi.cardeles at gmail.com
>>>                 <mailto:luigi.cardeles at gmail.com>
>>>                 <mailto:luigi.cardeles at gmail.com>>> wrote:
>>>                 > Hi list,
>>>                 > maybe there are other problem (relate to pyqgis):
>>>                 > Não foi possível carregar PyQGIS.
>>>                 > Suporte à Python vai ser desabilitado.
>>>                 > Traceback (most recent call last):
>>>                 >   File "", line 1, in
>>>                 > RuntimeError: the sip module implements API v7.0
>>>                 but the
>>>                    qgis.core module
>>>                 > requires API v6.0
>>>                    This looks like you've updated sip package in
>>>                 your system, however
>>>                    qgis python module still awaits older version.
>>>                    - if you run self-compiled qgis, just recompile
>>>                 it and install again.
>>>                    It should adapt to newer sip version
>>>                    - if you run qgis from a distribution package,
>>>                 request an updated
>>>                    package from the packager
>>>                    - you could downgrade sip package and all
>>>                 packages that depend on it
>>>                    (PyQt, PyKDE) but I wouldn't recommend that as it
>>>                 might break your
>>>                    system
>>>                    Martin
>>>                 This mail was received via Mail-SeCure System.
>>>                 _______________________________________________
>>>                 Qgis-user mailing list
>>>                 Qgis-user at lists.osgeo.org
>>>                 <mailto:Qgis-user at lists.osgeo.org>
>>>                 http://lists.osgeo.org/mailman/listinfo/qgis-user
>>>             Micha Silver
>>>             Arava Development Co. +972-52-3665918
>>>             http://surfaces.co.il
>>>         Qgis-user at lists.osgeo.org  <mailto:Qgis-user at lists.osgeo.org>
>>         Micha Silver
>>         http://www.surfaces.co.il/
>>     _______________________________________________ Qgis-user mailing
>>     list Qgis-user at lists.osgeo.org <mailto:Qgis-user at lists.osgeo.org>
Micha Silver
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20100304/99352b5f/attachment.html>
