[Qgis-user] gdal tools & osgeo4w
Giovanni Manghi giovanni.manghi at gmail.com
Fri Mar 5 08:37:12 PST 2010
> Verify that %OSGEO4W_ROOT%\apps\gdal-16\pymod is in your PYTHONPATH.  If you
> use the batch file from the package to start qgis, that should already be set
> as it sources gdal16.bat
it seems everything is in place.
For what I seen, it seems that the tools stopped to work in the past
days after I updated the packages of my osgeo4w installation. Doing a
fresh installation on other pcs actually does not seems to give better
results, and depending on the windows version the errors are (examples):
Under XP there are modules (clip, merge) that return the following
File "C:\osgeo4w\apps\gdal-16\bin\gdal_merge.py", line 31, in
import gdal
ImportError: No module named gdal
Under Seven there are modules that throw this
"The process crashed some time after starting successfully."
while others give
  File "C:\Users\Nuno\.qgis\python\plugins\GdalTools\tools\doMerge.py",
line 50, in fillInputFilesEdit
    (self.xmax, self.ymax, self.xmin, self.ymin) = self.getExtent()
line 119, in getExtent
    res = rect1.intersect( rect2 )
AttributeError: 'NoneType' object has no attribute 'intersect'
Python version:
2.5.2 (r252:60911, Feb 21 2008, 13:11:45) [MSC v.1310 32 bit (Intel)]
I have also tested a Vista machine and with few modules, when adding
input files, it returns a
"gdalinfo.exe has stopped working"
followed by
An error has occured while executing Python code:
  File "C:\Users\gio\.qgis\python\plugins\GdalTools\tools\doMerge.py",
nevertheless you can continue but just to get
File "C:\OSGeo4W\apps\gdal-16\bin\gdal_merge.py", line 31, in
import gdal
other tools give (after the "crash")
cheers
-- Giovanni --
