[Qgis-user] Segmentation fault...
Micha Silver micha at arava.co.il
Sat Mar 6 07:37:12 PST 2010
David J. Bakeman wrote:
> Micha Silver wrote:
>> On 03/04/2010 03:43 AM, Luigi Castro Cardeles wrote:I'm also still
>> stuck with QGIS segfaulting. I find:
>> * It happens Only in Gnome (xfce and KDE work fine on the same
>> machine, with the same binary)
>> * When running as super user the segfault disappears.
>> * I tried Luigi's suggestion to change the default Qt style in
>> qtconfig-qt4, but I still get the same segfault...
>> * It started after an update to some qt packages on Feb 24.
> I can confirm this.  I had made the qtconfig change way back when
> another qt update caused all qt apps to crash when using gnome.  Now
> it crashes anytime I'm using gnome which is my preferred WM.  I did
> finally get it to work by running a vnc session in xfce and then
> starting qgis as root in that vnc.  Running as root in gnome crashes
> for me.  I'm going to try the latest svn soon I'm using a personally
> build 1.4 qgis rpms now.
Thanks for the additional info. Please report back when you compile the
svn version (Didn't help me :-(  )
>> Any ideas where to report this problem to Gnome/Qt devs?
I opened a ticket on Redhat's bugzilla system [1], and immediately got a
reply that the bug is a duplicate of a similar Gnome bug [2] from nearly
a year ago.
While the results seem similar, I doubt it's the same bug as all library
versions have bumped up since then.
But I'll try the patch suggested [3] to gdal (!) to see if it helps.
[1] https://bugzilla.redhat.com/show_bug.cgi?id=570768
[2] https://bugzilla.redhat.com/show_bug.cgi?id=498111
[3] https://bugzilla.redhat.com/attachment.cgi?id=341828&action=edit
Micha Silver
Arava Development Co. +972-52-3665918
http://surfaces.co.il
