[Qgis-user] QGIS for Windows: can the directory ".qgis/python/plugind" be moved?
Þórður Ívarsson toti at pukar.net
Sun Mar 7 11:26:37 PST 2010
Fine, I was only notifying of the problem, I am used to all kinds of such problems regarding Icelandic characters in filenames, therefor I was not bothered. But now it has been fixed, and many Icelandic users will not have the problem anymore.
Thordur
-----Original Message-----
From: Giovanni Manghi [mailto:giovanni.manghi at gmail.com]
Sent: 7. mars 2010 19:19
To: Þórður Ívarsson
Cc: Agustin.Lobo at ija.csic.es; 'qgis-user'
Subject: RE: [Qgis-user] QGIS for Windows: can the directory ".qgis/python/plugind" be moved?
The problem has already been fixed by Jurgen. Starting from the next dev
version available with the osgeo4w installer (tomorrow), you should not
have more problems.
cheers
-- Giovanni --
On Sun, 2010-03-07 at 19:10 +0000, Þórður Ívarsson wrote:
> I also hit this problem, my Icelandic name conflicts and no plugins work, if
> I use my real name as windows user
> Thordur Ivarsson
> From: qgis-user-bounces at lists.osgeo.org
> [mailto:qgis-user-bounces at lists.osgeo.org] On Behalf Of Agustin Lobo
> Sent: 7. mars 2010 11:33
> To: qgis-user
> Subject: [Qgis-user] QGIS for Windows: can the directory
> The current windows install sets the
> .qgis/python/plugind directory under
> C:/Documents and Settings/username
> which results on general plugin failure in the case "username" has non-ascii
> characters, i.e.
> 'C:/Documents and Settings/Mauro Rodríguez Rey/.qgis//python'
> Is it possible to optionally set the .qgis directory to another
> place to avoid this problem?
> (does anybody know if this problem has been reported as a ticket? I've
> searched
> and could not find it, but it's not easy to search for an appropriate
> keyword in
> this case).
> Thanks
> Agus
> Qgis-user mailing list
> This message has been scanned for viruses and
> dangerous content by MailScanner, and is
> believed to be clean.
