[Qgis-user] Fetch plugins crashing
Richard Duivenvoorde rdmailings at duif.net
Thu Mar 11 23:59:07 PST 2010
Hi Joe,
some things you could try:
- rename the .qgis-folder in your home, and start qgis (which will then
make a new one. You can then see if this still happens without all the
plugins (which qgis can't see now because they are in the renamed folder)
- if still crashing. Try removing the 'plugin_installer' plugin temporarily
- if still crashing: try starting qgis with 'strace' (if not installed,
install first).  If you start qgis from commandline then:
	strace qgis
you will have a long (!) list of messages from which the last part maybe
shows you what went wrong...
how did you install qgis anyway: from respository or building your own?
(I'm running my from trunk compiled qgis on ubuntu 9.10 without
problems)... what version of python do you have?
Regards,
Joe Public wrote:
> Hello:
> I am using QGIS version 1.4 on Ubuntu 9.10.
> When I click on "fetch Pyhton plugins" the QGIS app disappears(crashes)
> I deleted all traces of the old version before installing QGIS 1.4
> I tried sudo qgis to make sure it was not a permissions issue and it still
> crashed
> This is what I get when I start QGIS from the command prompt:
> Python support ENABLED :-)
> Loaded : fTools (package: fTools)
> Loaded : Plugin Installer (package: plugin_installer)
> Warning: QObject::connect: Incompatible sender/receiver arguments
>         QgsProject::writeProject(QDomDocument&) -->
> QgisApp::projectChanged(QDomDocument)
> Any thing I can do the solve this problem
> Thanks
> Joe
> PS: The program works fine otherwise
