[Qgis-user] gdalbuildvrt on win7 crashes
Giuseppe Sucameli brush.tyler at gmail.com
Sat Mar 13 11:03:35 PST 2010
Hi all,
this problem is only on Vista and Seven.
On Sat, Mar 13, 2010 at 7:21 PM, Mike Swope <mswope at gmail.com> wrote:
> When I try to run the build vrt from the qgis menu on x64 win 7, it seems
> to crash every time. I'm using the osgeo4win packages, and have both 1.4 and
> 1.0. The menu item starts fine, and I select several files, then (no matter
> on the other option) it seems to crash. I've not tried the cli for this. Has
> anyone been able to create a vrt with qgis?
All gdal .exe tools (buildvrt, contour, rasterize,
nearblack, warp, grid, translate, information,
assign projection, build overviews) display this
error, but they return also a correct result, so
you can load the output result by adding the output
as raster/vector layer.
We're trying to find a solution soon.
Cheers.
Giuseppe Sucameli
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20100313/755d7cad/attachment.html>
