[Qgis-user] Re: QGIS1.4.0 With GRASS - Windows Installer
Agustin Lobo alobolistas at gmail.com
Fri Mar 19 03:27:07 PDT 2010
Thanks Kumaran,
According to what I've been able to test up to now,
some programs in the Raster tab still do not work:
File "C:\QuantumGIS-1.4\apps\gdal-16\bin\gdal_proximity.py", line 35, in
import gdal
File "C:\osgeo\apps\Python25\lib\site-packages\gdal.py", line 2, in
File "C:\osgeo\apps\Python25\lib\site-packages\osgeo\gdal.py", line 7, in
ImportError: No module named _gdal
File "C:\QuantumGIS-1.4\apps\gdal-16\bin\gdal_polygonize.py", line 34, in
import gdal, ogr, osr
Instead, contour, RasterCalc and Raster-based terrain analysis work fine
I'll keep you posted of any errors I find.
Many thanks for your work.
Agus
Kumaran Narayanaswamy [via OSGeo.org] wrote:
> Hello Agus,
> The below issues listed has been resolved and all these plugins will work
> without installing additional tools. They have been packaged well in this
> build.
> http://kcubeconsulting.com/download.php
> Please test and let us know if you face any issues.
> We have also packaged a latest version from trunk(r13054) for Windows with
> GRASS for early adopters and testers.
> Regards
> Kumaran
> -----Original Message-----
> From: [hidden email]
> <http://n2.nabble.com/user/SendEmail.jtp?type=node&node=4741591&i=0>
> [mailto:[hidden email]
> <http://n2.nabble.com/user/SendEmail.jtp?type=node&node=4741591&i=1>] On
> Behalf Of Agustin Lobo
> Sent: Monday, February 08, 2010 7:18 PM
> To: [hidden email]
> <http://n2.nabble.com/user/SendEmail.jtp?type=node&node=4741591&i=2>
> Subject: [Qgis-user] Re: QGIS1.3.0 Mimas With GRASS - Windows Installer
> Kumaran,
> As far as I've been able to test, the version of qgis 1.4.0 from the
> kcubeconsulting server has problems with the following plugins:
> DEM relief (gdal missing)
> GDALtools (osgeo missing)
> RasterCalc (pyparsing missing)
> Scattergram (WQWt5 missing)
> I've solved the problem with pyparsing by
> downloading the zip file
> http://sourceforge.net/projects/pyparsing/files/pyparsing/pyparsing-1.5.2/py
> parsing-1.5.2.zip/download
> and copying
> pyparsing.py
> pyparsing_py3.py
> to
> C:\QuantumGIS\apps\Python25\Lib\site-packages
> as told by Alexander here:
> http://n2.nabble.com/RasterCalc-tt4438577.html#none
> but the missing osgeo.gdal is a problem for RasterCalc as well.
> Perhaps you could add the necessary support for these important packages?
> I know these issues can be solved by the osgeo4w installer, but an
> standalone
> installer makes things a lot easier for a course.
> Thanks
> Agus
> http://n2.nabble.com/QGIS1-3-0-Mimas-With-GRASS-Windows-Installer-tp4121469p
> 4534182.html
> Sent from the qgis-user mailing list archive at Nabble.com.
> Qgis-user mailing list
> [hidden email]
> <http://n2.nabble.com/user/SendEmail.jtp?type=node&node=4741591&i=3>
> [hidden email]
> <http://n2.nabble.com/user/SendEmail.jtp?type=node&node=4741591&i=4>
> View message @
> http://n2.nabble.com/QGIS1-3-0-Mimas-With-GRASS-Windows-Installer-tp4121469p4741591.html
> To unsubscribe from Re: QGIS1.3.0 Mimas With GRASS - Windows Installer,
> click here
> <http://n2.nabble.com/subscriptions/Unsubscribe.jtp?code=YWxvYm9saXN0YXNAZ21haWwuY29tfDQ1MzQxODJ8LTE4NjIyNjM0ODI=>.
