[Qgis-developer] Re: [Qgis-user] CRS for a start
Micha Silver micha at arava.co.il
Mon Mar 22 00:35:09 PDT 2010
On 22/03/2010 01:14, Carson Farmer wrote:
> Hello All,
>> MN>  I mean in QGIS I can open now a holiday photo, go to layer properties
>> MN>  and get an impresion from it's metadata, that it is already
>> MN>  georeferenced:
>> MN>  "Layer Spatial Reference System:
>> MN>  +proj=longlat +ellps=WGS84 +datum=WGS84 +no_defs"
>> MN>  which is of course not true. But we have to think about novice GIS
>> MN>  users who might either go dizzy or get bad habits.
>> I agree, the layer properties should not use this as default if prj is
>> missing or should clearly indicate somehow that this is a guessed CRS,
>> not necessarily a real one.
> I agree as well. In case of no prj or other CRS information and no
> default CRS defined, it would likely be best if the CRS was set to
> "Unknown (Assumed Geographic)" or something like this. It wouldn't be
> too hard to add this to the current CRS db as an additional available
> CRS, and when users have a quick look at a layer's CRS, they will
> instantly see that they have to properly define the CRS if they want
> to use the layer properly.
Thanks for bringing this issue up again. (It's been on the list before
but I can't find the link just now). The ways to deal with layers of
unknown projection were named (not by me) the "GRASS way" and the "Arc way":
GRASS forces the user to choose a CRS at program startup, then each
layer must match that CRS. NO o-t-f re-projection. Arc* starts in the
CRS of the first layer, then automatically does o-t-f re-projection
without any notification.
GRASS is a bit more difficult, but better in some ways. Arc* is a bit
easier but has some unfortunate disadvantages.
The behavior I'd like to see in QGIS is- allow users to choose which
system they want. It could work well, I think, as follows:
In the Options->CRS tab I can choose a global CRS. Currently this CRS
applies only to new layers (if I select that option). I would like to
see an additional option to apply the Global CRS to all new *projects*
including CRS units.
So after a user chooses a global CRS, he can then select if he wants it
to apply to all layers with unknown CRS (as is now), and he can also
choose if it should be the default for all new projects. This would
serve for those who always work in the same CRS, but not epsg:4326. Then
there should be a third option, to prompt for project CRS on each
opening of a new project (aka the GRASS way) for those who jump between
between different coordinate systems.
Then, as others mentioned, there should be some visual notification that
a layer will not be visible (i.e. raster in a different CRS) or that its
projection is unknown.
Thanks,
Micha
> Just my two cents!
> Carson
Micha Silver
http://www.surfaces.co.il/
Arava Development Co.  +972-52-3665918
