[Qgis-user] Point selection and export
flavio rigolon flavio.rigolon at gmail.com
Fri Mar 26 00:04:01 PDT 2010
Hi Brett,
Hi Folks,
> I've imported some vector points and now want to export only the points
> from a selected area. "Select features" allows the selection of points
> within a square, which is not the shape or orientation I require. Can I
> create my own polygon for point selection?
You can do this installing the plugin "selectplus". After that you'll fine a
new menu (SelectPlus) to do what you want.
hth
flaviio
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20100326/1a165b92/attachment.html>
