[Qgis-user] DXF import
Brett Adams badams.spinifex at gmail.com
Wed Mar 31 18:40:20 PDT 2010
Found a solution.
The Dxf2Shp will work with 2D DXF's but not 3D DXF's.
Handy if you have the ability to generate 2D.
On 30/03/2010 3:26 PM, Stefan Kiefer wrote:
> Hi,
> without having a deeper view in the plugin I would expect that
> importing dxf is quite difficult anyway. The main issue is that dxf
> contains multiple geometric formats (polylines, lines, points,
> annotations, splines ...) mixed in different layers! Whereas a shape
> can contain only one single geometric format in one single layer! I
> would belive that the plugin is not as sophisticated as the import
> routines of programs with many years of experience with dxf.
> Anyway my sugestion is to use Grass to import dxf an convert to shape
> or use Grass layers in Qgis. I had good experience this way. Otherwise
> Grass can manage layers and can convert geometric formats. More over
> it can clean and build the topology (maybe this is why your import fails).
> cheers
> Stefan
> Am Dienstag, den 30.03.2010, 14:54 +0800 schrieb Brett Adams:
>> Hi Folks,
>> Having some problems importing DXF's using the DXF2SHP plug-in.  Often
>> all I get is a centre point, not the rest of image. Occasionally it will
>> work properly. I'm having the most success importing them as Pollyline.
>> Other programs load the DXF's fine. It's just QGIS that is giving me
>> trouble.
>> Any ideas?
Brett Adams
Spinifex Geophysics
0438 861 974
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20100401/4116f4ac/attachment.html>
