[Qgis-user] Edit UI
Einar Guðsteinsson einsigu at simnet.is
Tue Mar 16 15:27:11 EDT 2010
Ofcorse when I just had hit send I managed todo this. using wrong combobox.
All is good. thanx!
Sent: Tuesday, March 16, 2010 7:23 PM
To: "Andreas Neumann" <a.neumann at carto.net>; "Richard Duivenvoorde"
<rdmailings at duif.net>
Cc: <qgis-user at lists.osgeo.org>
Subject: Re: [Qgis-user] Edit UI
> This was easy. And I managed todo what I needed exept for one thing. One
> of my attribute is Value map. Was trying to go for combobox there. Any
> hint on how I can managed to get my values in the combobox?
> Einar
> From: "Andreas Neumann" <a.neumann at carto.net>
> Sent: Tuesday, March 16, 2010 11:11 AM
> To: "Richard Duivenvoorde" <rdmailings at duif.net>
> Cc: "EinarGuðsteinsson" <einsigu at simnet.is>; <qgis-user at lists.osgeo.org>
>> designing forms with qt-designer is not that hard. Even I know how to do
>> it - and I am not a C++ programmer. You have to make sure that the widget
>> is compatible with the data type and that the widget names correspond
>> with
>> the attribute column names.
>> The other tricky part is to use layouts and spacers: grid and form
>> layout.
>> This helps to ensure that your forms can be resized and the widgets in
>> the
>> layout will resize as well. Sometimes it may be frustrating if you invest
>> a lot of time to arrange widgets - then you apply a layout and it
>> rearranges a lot ...
>> All the rest is not really complicated.
>> Andreas
>> On Tue, March 16, 2010 7:21 am, Richard Duivenvoorde wrote:
>>> Einar Guðsteinsson wrote:
>>>> Ouch, one dev tool more to learn.... when day will be 26 hours :-)  Can
>>>> I use action or something else to set default value?  one field is
>>>> string with date and I want today always to be automaticly filled in.
>>> Hi Einar,
>>> 26 hours to learn qt-designer etc is maybe not enough. But it's nice to
>>> know and using it in combination with a python plugin gives probably
>>> what you want.
>>> another option is
>>> http://linfiniti.com/2009/11/creating-dynamic-forms-a-new-feature-headed-for-qgis-1-4/
>>> which gives you without ui-file very very simple input forms (which
>>> according the article you can even then manipulate using python
>>> (plugin).
>>> Not sure about the last part...
>>> Regards Richard Duivenvoorde
>>> Qgis-user mailing list
>>> Qgis-user at lists.osgeo.org
>>> http://lists.osgeo.org/mailman/listinfo/qgis-user
>> Andreas Neumann
>> http://www.carto.net/neumann/
>> http://www.svgopen.org/
