[Qgis-user] Re: Qgis-user Digest, Vol 51, Issue 7
Kumaran Narayanaswamy kumaran.narayanaswamy at kcubeconsulting.com
Thu May 6 23:24:54 PDT 2010
After you import the gpx file first save it as a shapefile and then you can
start editing.
Kumaran
-----Original Message-----
[mailto:qgis-user-bounces at lists.osgeo.org] On Behalf Of Sajid Iqbal
Sent: Friday, May 07, 2010 10:29 AM
To: qgis-user at lists.osgeo.org
Subject: [Qgis-user] Re: Qgis-user Digest, Vol 51, Issue 7
Hello sir,
           i have a serious issue i.e
I add a layer on qgis and want to edit a waypoint and followed the below
steps
1 add layer
2 wright click on layer on left side on layer manue
3 click toggle editing
4 salect the waypoint
5 move vertex and drag the waypoint on the wright place you want to be fix
important not is that edit colum is not highligted and also i m unable
to salect the field
On Thu, May 6, 2010 at 9:00 PM,  <qgis-user-request at lists.osgeo.org> wrote:
> Send Qgis-user mailing list submissions to
> To subscribe or unsubscribe via the World Wide Web, visit
>        http://lists.osgeo.org/mailman/listinfo/qgis-user
> or, via email, send a message with subject or body 'help' to
> You can reach the person managing the list at
>        qgis-user-owner at lists.osgeo.org
> When replying, please edit your Subject line so it is more specific
> than "Re: Contents of Qgis-user digest..."
> Today's Topics:
>   1. Re: qgis compiling error (flavio rigolon)
> Message: 1
> Date: Thu, 6 May 2010 17:37:12 +0200
> From: flavio rigolon <flavio.rigolon at gmail.com>
> Subject: Re: [Qgis-user] qgis compiling error
> To: Pierre Chevalier G?ologue <pierrechevaliergeol at free.fr>
> Cc: qgis-user <qgis-user at lists.osgeo.org>
> Message-ID:
>        <s2w2ce45db01005060837sbee72a0wb3efc83e4b293257 at mail.gmail.com>
> Content-Type: text/plain; charset="utf-8"
> 2010/5/6 Pierre Chevalier Géologue <pierrechevaliergeol at free.fr>
>> Hello,
> Hi Pierre,
>> I had the same kind of error, also on debian testing. I tried many
>> different things, and it eventually worked out, I'm not exactly sure what
>> exactly worked...  It may be a mess between sip and sip4 packages?
>> Here are the last things I did, as root, just before it worked, according
>> to my /root/.bash_history:
>>   apt-get install gdal-bin libgdal1-dev libgeos-dev proj libgdal-doc
>>  python-dev libgsl0-dev g++ libjasper-dev libtiff4-dev subversion
>>   libsqlite3-dev sqlite3 ccache make libpq-dev flex bison cmake
>>   txt2tags python-qt4 python-qt4-dev python-sip4 sip4 python-sip4-dev
>>   apt-get install cmake
>>   apt-get install grass libgrass-dev
>>   apt-get install grass grass-dev
>>   cd /usr/local/bin
>>   sudo ln -s /usr/bin/ccache gcc
>>   sudo ln -s /usr/bin/ccache g++
>>   apt-get install build-essential g++ subversion
> I've followed your suggestions but the error is the same.....thanks
anyway.
> flavio
> -------------- next part --------------
> An HTML attachment was scrubbed...
> URL:
http://lists.osgeo.org/pipermail/qgis-user/attachments/20100506/5b556efa/att
achment-0001.html
> End of Qgis-user Digest, Vol 51, Issue 7
Warm Regards,
Sajid Iqbal
PakVista Technologies Co. (Pvt) Ltd.
Office No.18, 3rd Floor, Select Center,
F-11 Markaz - Islamabad.
Office: +92 51 831 4504-5
Cell : +92 300  915  4403
URL: www.pakvistatech.com
<http://www.pakvistatech.com/>
