[Qgis-user] WMS through https and basic auth
Jürgen E. Fischer jef at norbit.de
Tue May 11 01:12:38 PDT 2010
Hi Jukka,
On Mon, 10. May 2010 at 16:52:43 +0300, Rahkonen Jukka wrote:
> Then I obviously need to keep waiting.  Osgeo4w installation just a moment
> ago installed r13432 for me and you just told that it comes without SSL
> anyway.
> And I am also almost sure that it will not support these two certificates we
> are using: http://www.fineid.fi/certs/vrkrootc.crt
> http://www.fineid.fi/certs/vrksp.crt
Did you try?
> > I would have expected that InteProxy also rewrites the GetCapabilities
> > response...
> I can write to Invatiotion and ask if they have considered it.
Ok.  I took a quick look and didn't see anything in that direction.  But the
seem to show the fee information from GetCapabilities...
> > > 1. Is QGis 1.5.0 supposed to support https communication on Windows?
> > Not earlier - but now it should now.  Although I just discovered that the
> > osgeo4w Qt seems to be build without SSL support.
Should be fixed.
> > Sounds reasonable.  Would you file a ticket for it?
Ticket done too.
Jürgen
Jürgen E. Fischer         norBIT GmbH               Tel. +49-4931-918175-20
Dipl.-Inf. (FH)           Rheinstraße 13            Fax. +49-4931-918175-50
Software Engineer         D-26506 Norden               http://www.norbit.de
norBIT Gesellschaft fuer Unternehmensberatung und Informationssysteme mbH
Rheinstrasse 13, 26506 Norden
GF: Jelto Buurman, HR: Amtsgericht Emden, HRB 5502
