[Qgis-user] Re: Qgis-user Digest, Vol 51, Issue 19
Iyappan Lakshmanan iyappan100 at gmail.com
Wed May 12 19:57:35 PDT 2010
You can use SAGA GIS to short out your problem.
On Thu, May 13, 2010 at 1:25 AM, <qgis-user-request at lists.osgeo.org> wrote:
> Send Qgis-user mailing list submissions to
>        qgis-user at lists.osgeo.org
> To subscribe or unsubscribe via the World Wide Web, visit
>        http://lists.osgeo.org/mailman/listinfo/qgis-user
> or, via email, send a message with subject or body 'help' to
> You can reach the person managing the list at
>        qgis-user-owner at lists.osgeo.org
> When replying, please edit your Subject line so it is more specific
> than "Re: Contents of Qgis-user digest..."
> Today's Topics:
>   1. Creating polygon from points in csv file (mir)
>   2. GPS CRS (Arthur Nanni)
>   3. Re: GPS CRS (Alex Mandel)
>   4. Re: Creating polygon from points in csv file (nikos ves)
>   5. Re: Creating polygon from points in csv file (M S)
>   6. Re: Creating polygon from points in csv file (nikos ves)
>   7. Re: Creating polygon from points in csv file (Gerald Creager)
>   8. Re: Creating polygon from points in csv file (nikos ves)
> Message: 1
> Date: Wed, 12 May 2010 12:11:40 -0500
> From: mir <mir123 at gmail.com>
> Subject: [Qgis-user] Creating polygon from points in csv file
> To: qgis-user at lists.osgeo.org
> Message-ID:
>        <AANLkTin4XbjcvZJZIro9BFk0G_FjuVcmn0Jb_4UfGovl at mail.gmail.com>
> Content-Type: text/plain; charset=ISO-8859-1
> Hello all,
> I have a list of points in sequence that define a polygon.  This is
> taken from a legal document defining a piece of land.  So far I have
> been able to import this into Qgis as points.  How do I import it as a
> polygon (or convert the points to a polygon?  I have tried to use
> GRASS, importing it as an ASCII file, but I guess I never got the
> ASCII polygon format down.
> I'm sure there must be an asy way.  Help!
> mir
> _________________
> Mir Rodríguez Lombardo
> Fundación Almanaque Azul
> Calle 4a San Felipe, antigua Santa Familia
> Ciudad de Panamá
> tel +507 836 6452
> cel 6644 9214
> Message: 2
> Date: Wed, 12 May 2010 14:34:42 -0300
> From: Arthur Nanni <arthur.nanni at gmail.com>
> Subject: [Qgis-user] GPS CRS
> Message-ID:
>        <AANLkTil6L9ff49fdU4863J_ugnx7xDkJtDmXwnaPkcpq at mail.gmail.com>
> Content-Type: text/plain; charset="iso-8859-1"
> Hi,
> I've problems whem I try download waypoints from Garmin GPS with GPS plugin
> in the same CRS of the Garmin setup.
> The Garmin was WGS84 - UTM
> In the QGIS canvas the downloaded points appears in Lat/Long decimal
> degree.
> How I get this points in the original CRS of Garmin?
> Like an alternative I try change the CRS in the layer (Lat/Long DD) with
> ftools option, but with no success.
> Some idea?
> Thanks in advance.
> Arthur
> Chegou Ubuntu Linux 10.04. Experimente a liberdade! Conheça em
> http://www.ubuntu-br.org
> -------------- next part --------------
> An HTML attachment was scrubbed...
> URL:
> http://lists.osgeo.org/pipermail/qgis-user/attachments/20100512/3885b9f3/attachment-0001.html
> Message: 3
> Date: Wed, 12 May 2010 10:43:24 -0700
> From: Alex Mandel <tech_dev at wildintellect.com>
> Subject: Re: [Qgis-user] GPS CRS
> To: Arthur Nanni <arthur.nanni at gmail.com>
> Cc: qgis-user at lists.osgeo.org
> Message-ID: <4BEAE8BC.8020206 at wildintellect.com>
> Arthur Nanni wrote:
> > Hi,
> plugin
> degree.
> > Some idea?
> > Thanks in advance.
> The original CRS of the Garmin is WGS 84 Lat/Long. The fact that you saw
> UTM on the screen is an on the fly conversion on the GPS. Most Garmins
> for many years have only stored Lat/Long in it's actual data.
> You will need to download the data and reproject(in ftools) it to the
> UTM zone you are working in.
> Alex
> Message: 4
> Date: Wed, 12 May 2010 20:49:43 +0300
> From: nikos ves <vesnikos at gmail.com>
> Subject: Re: [Qgis-user] Creating polygon from points in csv file
> To: mir <mir123 at gmail.com>
> Message-ID: <1273686583.16209.4.camel at nikos-desktop>
> Content-Type: text/plain; charset="UTF-8"
> On Wed, 2010-05-12 at 12:11 -0500, mir wrote:
> > Hello all,
> > mir
> You can use the "Points2One" plugin which makes the task you need.
> As input takes a point layer and as output gives a polygon or a
> polyline. In your case you can choose polygon.
> Be careful with the order of the points, otherwise you might get funny
> results.
> eg      |1 2|  is fine , but
>        |4 3|
>        |1 2| will intersect with itself, making two triangles!
>        |3 4|
> Ves Nikos
> Message: 5
> Date: Wed, 12 May 2010 13:51:29 -0400
> From: M S <mseibel at gmail.com>
> Message-ID:
>        <AANLkTilMIa18pLtRLfZjb8cM3WlWpXiWGDPATxItIwtY at mail.gmail.com>
> I guess the practically of this suggestion depends on how many points.
>  How about digitizing and snapping the new polygon to the points?
> Mark
> On Wed, May 12, 2010 at 1:11 PM, mir <mir123 at gmail.com> wrote:
> > Hello all,
> > mir
> > _________________
> > Ciudad de Panamá
> > tel +507 836 6452
> > cel 6644 9214
> > Qgis-user at lists.osgeo.org
> Message: 6
> Date: Wed, 12 May 2010 21:02:54 +0300
> Message-ID: <1273687374.16209.13.camel at nikos-desktop>
> > Mark
> This would also work, but the why bother, since already has the points
> in a csv file?
> One problem I see, is multiple polygones merged in One big messy
> polygone due to hte fact that it cant "understand" where a polygon ends
> and the next one starts. If that case arise  a little editing comes
> handy.
> The whole point as I see it is to minimize doing double work
> Ofcouse if the plugin is inadequate for the job, the next option is to
> shape the polygons from, as Mark said, the points mir already has
> utilizing the snap feature
> > > Hello all,
> > > mir
> > > _________________
> > > Ciudad de Panamá
> > > tel +507 836 6452
> > > cel 6644 9214
> Message: 7
> Date: Wed, 12 May 2010 13:44:31 -0500
> From: Gerald Creager <gerry.creager at tamu.edu>
> To: nikos ves <vesnikos at gmail.com>
> Message-ID: <4BEAF70F.7050401 at tamu.edu>
> Content-Type: text/plain; charset=UTF-8; format=flowed
> Nikos, will Points2One work for lines, as well, or just for polygons? I
> have a similar issue: I need to create polylines from a CSV file... I,
> too, can digitize the points into lines, but, why?
> Thanks Gerry
> >> Mark
> > in a csv file?
> > handy.
> >>> Hello all,
> >>> mir
> >>> _________________
> >>> Ciudad de Panamá
> >>> tel +507 836 6452
> >>> cel 6644 9214
> Gerry Creager -- gerry.creager at tamu.edu
> Texas Mesonet -- AATLT, Texas A&M University
> Cell: 979.229.5301 Office: 979.458.4020 FAX: 979.862.3983
> Office: 1700 Research Parkway Ste 160, TAMU, College Station, TX 77843
> Message: 8
> Date: Wed, 12 May 2010 22:55:27 +0300
> To: gerry.creager at tamu.edu
> Message-ID: <1273694127.19243.29.camel at nikos-desktop>
> > Thanks Gerry
> Just test it, It successfully made a line across all the points, except
> for the inconvenience that is making just ONE line.
> Unfortunately, as I've found, QGIS lacks vertex-level editing (delete
> multiple vertices in line/polygon; move multiple vertices) at least in
> v1.1 which seems to be the case in 1.5.
> > >> Mark
> > > in a csv file?
> > > handy.
> > >>> Hello all,
> a
> > >>> mir
> > >>> _________________
> > >>> Ciudad de Panamá
> > >>> tel +507 836 6452
> > >>> cel 6644 9214
> End of Qgis-user Digest, Vol 51, Issue 19
L.Iyappan M.Tech Remote Sensing
CEO & Founder of Magendhiran Consultancy Services
5,3rd Street, Gandhi Nagar, Kanchipuram,
Near Chennai, Tamil Nadu, India
Mobile: +91-9047134181
Mail: iyappan.l at mcsmapping.com
web: www.mcsmapping.com
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20100513/4f4d3b78/attachment.html>
