[Qgis-user] Creating polygon from points in csv file
mir
mir123 at gmail.com
Fri May 14 12:48:11 PDT 2010
Perfect, Points2One worked straight away! Thank you all very much.
mir
On 12 May 2010 12:49, nikos ves <vesnikos at gmail.com> wrote:
> On Wed, 2010-05-12 at 12:11 -0500, mir wrote:
>> Hello all,
>> I have a list of points in sequence that define a polygon. This is
>> taken from a legal document defining a piece of land. So far I have
>> been able to import this into Qgis as points. How do I import it as a
>> polygon (or convert the points to a polygon? I have tried to use
>> GRASS, importing it as an ASCII file, but I guess I never got the
>> ASCII polygon format down.
>> I'm sure there must be an asy way. Help!
>> mir
> You can use the "Points2One" plugin which makes the task you need.
> As input takes a point layer and as output gives a polygon or a
> polyline. In your case you can choose polygon.
> Be careful with the order of the points, otherwise you might get funny
> results.
> eg |1 2| is fine , but
> |4 3|
> |1 2| will intersect with itself, making two triangles!
> |3 4|
> Ves Nikos
_________________
Mir Rodríguez Lombardo
Fundación Almanaque Azul
Calle 4a San Felipe, antigua Santa Familia
Ciudad de Panamá
tel +507 836 6452
cel 6644 9214
