[Qgis-user] Help on SDA4PP plugin
Hugo
hfpmartins at gmail.com
Wed May 26 10:47:56 PDT 2010
Hello all,
I was previously successful in installing sda4pp in another machine. Somehow
i'm not able to replicate the installation.
The system is the following:
Win XP SP3
QGIS 1.5 r13575M
R 2.10.1
GGOBI 2.1.8
I've installed all packages required by the SDA4PP plugin in rgui through *
install.packages*.
When i start qgis and go to the SDA4PP menu -> Components/R packages it says
that rgdal isn't installed. I have tried top remove the package and then
install rgdal through the plugin menu in qgis and the result is the same.
I have set environment variables for R and GGOBI.
Does anyone have an idea on how to solve this issue????
Thanks in advance,
Hugo
Hugo Martins
FMV-UTL
CIISA-Epidemiologia e Saúde Pública Veterinária
Av. da Universidade Técnica
1300-477 Lisboa
N 38°42'49.54", W 9°11'43.42"
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20100526/58dde621/attachment.html>
