[Qgis-user] google layers plugin projection
Agustin Lobo alobolistas at gmail.com
Fri May 28 06:56:31 PDT 2010
It does not in my case, if I use a vector on ED50 UTM31 and the
project set to a custom projectione defined as
+proj=merc +a=6378137 +b=6378137 +lat_ts=0.0 +lon_0=0.0 +x_0=0.0
+y_0=0 +k=1.0 +units=m +nadgrids=@null +wktext +no_defs
and onthefly activated: the vector is displaced ca. 100m vs the google
raster. This also happens with click-fu.
Agus
2010/5/28 maning sambale <emmanuel.sambale at gmail.com>:
>> +proj=merc +a=6378137 +b=6378137 +lat_ts=0.0 +lon_0=0.0 +x_0=0.0 +y_0=0 +k=1.0 +units=m +nadgrids=@null +wktext +no_defs
> This one works!  Thanks everyone.
> On Thu, May 27, 2010 at 7:16 PM, Jean-Claude Repetto <jcrml at mxm.eu> wrote:
>> Le 27/05/2010 11:55, Craig Leat a écrit :
>>> Ivan Mincik wrote:
>>>> Yes, GoogleLayers plugin is creating layers with custom proj definition
>>>> because in many proj instalations this
>>>> projection is missing.
>>>> Google projection definition:
>>>> +k=1.0 +units=m +nadgrids=@null +no_defs
>>> On my installation I found EPSG:3785 "Popular Visualisation CRS /
>>> Mercator" with the definition:
>>> +proj=merc +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=6378137 +b=6378137
>>> +towgs84=0,0,0,0,0,0,0 +units=m +no_defs
>> EPSG code 3785 is deprecated since 2009, and has been replaced by EPSG:3857.
>> Jean-Claude
>> Qgis-user mailing list
>> http://lists.osgeo.org/mailman/listinfo/qgis-user
> cheers,
> maning
> "Freedom is still the most radical idea of all" -N.Branden
> wiki: http://esambale.wikispaces.com/
> blog: http://epsg4253.wordpress.com/
