[Qgis-user] Grayscale GeoTiff and transparency using GDAL.
Pietro Panzeri
pietro.panzeri at treuropa.com
Mon May 31 01:42:17 PDT 2010
Hi all,
I'm writing a plugin using GDAL C library to allow the user to create a
grayscale GeoTiff with transparency.
I've used the following code to init the raster:
Driver = GDALGetDriverByName("GTiff");
papszOptions = CSLSetNameValue(papszOptions, "COMPRESS", "LZW");
Dataset = GDALCreate(Driver, SrcFilename, XSize, YSize, 2, GDT_Byte,
papszOptions);
Band1 = GDALGetRasterBand(Dataset, 1);
GDALSetRasterColorInterpretation(Band1, GCI_GrayIndex);
Band2 = GDALGetRasterBand(Dataset, 2);
GDALSetRasterColorInterpretation(Band2, GCI_AlphaBand);
Init the two bands
The result is a correct grayscale image but without transparency.
Can someone point me a way to create a grayscale GeoTiff with a
transparency?
Thank you very much.
Pietro
Pietro Panzeri
Software Development Manager
Tele-Rilevamento Europa - T.R.E. srl
Via Vittoria Colonna, 7
20149 Milano – Italia
Tel.: +39.02.4343.121 - Fax: +39.02.4343.1230
pietro.panzeri at treuropa.com - www.treuropa.com
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20100531/c187d68d/attachment.html>
