[Qgis-user] using manageR
Nobusuke Iwasaki wata909 at gmail.com
Fri Nov 12 05:05:25 PST 2010
Dear Patrick,
I had tried  to use R 2.10.1, QGIS 1.5 and manageR 1.0, but
unfortunately they did'nt work.
Thus, I'm using manageR 0.8 instead of manageR 1.0. They works well on
a Windows7 64bit.
You can download manageR 0.8 from
http://www.ftools.ca/cfarmerQgisRepo.xml
and install instead of manageR 1.0
http://www.ftools.ca/install.html
Best,
Nobusuke IWASAKI
2010/11/12 Dr. F. Patrick Graz <fgraz at unam.na>:
> Hi all,
> I have tried to get manageR to work on a windows XP box (R2.12 & QGIS
> 1.5/1.6)but don't seem to have any luck. To the best of my knowledge I have
> all the necessary extensions installed in R (ade4, aspace, sp, spgrass6,
> rgdal) adehabitat and have rpy2 installed.
> When I tried using QGIS 1.5 manageR would tell me that it could not find the
> r212.dll (I didn't write that error msg down...) but at least it tried...
> With 1.6 extension does not respond at all (i.e. you click on its icon and
> nothing happens).
> I have tried uninstalling and re-installing R and qgis but it's still not
> working. Where would I need to look to find out if my installation is
> sufficiently complete - and should be working. Is there a compatibility
> issue between the versions of the software - or software and extensions?
> Another thought - when I upgraded from R2.10 to R2.12 on an Ubuntu machine I
> could also not access manageR anymore...
> Any help would be welcome.
> Patrick
> Dr. F. Patrick Graz
> Snr. Researcher,
> Multidisciplinary Research Centre,
> University of Namibia
> Qgis-user mailing list
