[Qgis-user] How can I exporting KML for Google Maps
Aaron Kreider aaron at campusactivism.org
Fri Nov 12 13:39:22 PST 2010
I'm working on exporting US counties into a kml file so that I can use
it on Google Maps (ver 2).
Google Maps has a limit of 10mb for kml files.
I get a shapefile from the US Census Bureau (100mb).  I use the
"simplify geometries" feature to get it down to under 10mb.  Then I
"save as" kml.
Now I've got a kml that looks fine in Google Earth, QuantumGIS (1.5),
and ArcGis.  However it doesn't display in Google Maps (I see nothing
and there are no errors).   What is my problem?
You can see my kml: http://www.energyjustice.net/map/kml/counties01.kml
<http://www.google.com/url?sa=D&q=http://www.energyjustice.net/map/kml/counties01.kml&usg=AFQjCNFfXnlYA01s1cdgKQ11XDuvHa5ZAw>
You can see my html test page: http://www.energyjustice.net/map/ri.html
<http://www.google.com/url?sa=D&q=http://www.energyjustice.net/map/ri.html&usg=AFQjCNHq3AIJGiLbJGYbIR3WoFHn0j_OFg>
Here is my sample kml format:
?xml version="1.0" encoding="utf-8" ?>
<kml xmlns="http://www.opengis.net/kml/2.2
<http://www.google.com/url?sa=D&q=http://www.opengis.net/kml/2.2&usg=AFQjCNEwHFB9hZtWgJkNVAn37y41v7YyFA>">
<Document><Folder><name>counties01b</name>
<Schema name="counties01b" id="counties01b">
<SimpleField name="Name" type="string"></SimpleField>
<SimpleField name="Description" type="string"></SimpleField>
<SimpleField name="STATEFP00" type="string"></SimpleField>
<SimpleField name="COUNTYFP00" type="string"></SimpleField>
<SimpleField name="CNTYIDFP00" type="string"></SimpleField>
<SimpleField name="NAME00" type="string"></SimpleField>
<SimpleField name="NAMELSAD00" type="string"></SimpleField>
<SimpleField name="LSAD00" type="string"></SimpleField>
<SimpleField name="CLASSFP00" type="string"></SimpleField>
<SimpleField name="MTFCC00" type="string"></SimpleField>
<SimpleField name="UR00" type="string"></SimpleField>
<SimpleField name="FUNCSTAT00" type="string"></SimpleField>
</Schema>
<Placemark>
<name>19</name>
<description>175</description>
<Style><LineStyle><color>ff0000ff</color></LineStyle>
<PolyStyle><fill>0</fill></PolyStyle></Style>
<ExtendedData><SchemaData schemaUrl="#counties01b">
<SimpleData name="Name">19</SimpleData>
<SimpleData name="Description">175</SimpleData>
<SimpleData name="STATEFP00">19175</SimpleData>
<SimpleData name="COUNTYFP00">Union</SimpleData>
<SimpleData name="CNTYIDFP00">Union County</SimpleData>
<SimpleData name="NAME00">06</SimpleData>
<SimpleData name="NAMELSAD00">H1</SimpleData>
<SimpleData name="LSAD00">G4020</SimpleData>
<SimpleData name="CLASSFP00">M</SimpleData>
<SimpleData name="MTFCC00">A</SimpleData>
</SchemaData></ExtendedData>
<Polygon><outerBoundaryIs><LinearRing><coordinates>-94.470506,40.975042999999999,0
-94.470602999999997,41.157565999999996,0
-94.014188999999988,41.156762,0 -94.014803,40.897030999999998,0
-94.470778999999993,40.899501999999998,0
-94.470506,40.975042999999999,0</coordinates></LinearRing></
outerBoundaryIs></Polygon>
</Placemark>
</Folder></Document></kml>
Energy Justice Communities Map Developer - http://www.energyjustice.net/map
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20101112/5d2087fa/attachment.html>
