[Qgis-user] two little new plugins
Ivan Mincik ivan.mincik at gista.sk
Sun Nov 14 09:50:06 PST 2010
On 11/14/2010 05:39 PM, Möri Cedric wrote:
> Hi list
> I just released two little plugins: traceDigitize and numericalDigitize. Both work on vector layers which are in edit mode.
> NumericalDigitize just opens a dialog with a table where you may enter x/y-values. After clicking ok, it will add a feature to your vectorlayer. The type of the feature is according to your layertype (point,line or polygon).
> TraceDigitize works only for line and polygon layers. It allows to digitize new features by following existing lines or polygon boundaries. The tool will add all vertex points, that are in snapping distance of the cursor. Just press ctrl key while moving the mouse. If control isn't pressed, it is just like the normal digitize tool. Don't forget to set the (background) snapping options, as the tool needs them.
Perfect, thanks a lot for sharing.
Ivan Mincik, Gista s.r.o.
