[Qgis-user] NumericalDigitize and TraceDigitize
Dario darioqn at yahoo.com.br
Mon Nov 15 04:40:06 PST 2010
How to download NumericalDigitize and  TraceDigitize?
De: "qgis-user-request at lists.osgeo.org" <qgis-user-request at lists.osgeo.org>
Para: qgis-user at lists.osgeo.org
Enviadas: Segunda-feira, 15 de Novembro de 2010 1:07:33
Assunto: Qgis-user Digest, Vol 57, Issue 21
Send Qgis-user mailing list submissions to
To subscribe or unsubscribe via the World Wide Web, visit
    http://lists.osgeo.org/mailman/listinfo/qgis-user
or, via email, send a message with subject or body 'help' to
You can reach the person managing the list at
    qgis-user-owner at lists.osgeo.org
When replying, please edit your Subject line so it is more specific
than "Re: Contents of Qgis-user digest..."
Today's Topics:
  1. PostGIS viewer -PgAdmin plugin (Ivan Mincik)
  2. Re: two little new plugins (Ivan Mincik)
  3. Re: two little new plugins (Paolo Cavallini)
  4. Re: qgis oracle connection (Arto Vuorela)
  5. AW: [Qgis-user] two little new plugins (M?ri Cedric)
  6. Re: AW: [Qgis-user] two little new plugins (Paolo Cavallini)
  7. help me isolines;; (Rodrigo Moreira Maia)
  8. Re: help me isolines;; (Alex Mandel)
  9. Re: using manageR (Kumaran Narayanaswamy)
Message: 1
Date: Sun, 14 Nov 2010 18:48:59 +0100
Subject: [Qgis-user] PostGIS viewer -PgAdmin plugin
To: qgis-user <qgis-user at lists.osgeo.org>
Message-ID: <4CE0210B.7070709 at gista.sk>
Content-Type: text/plain; charset="utf-8"
I have created small standalone QGIS app, which I use as PgAdmin plugin
to visualize my PostGIS layers.
If anybody interested, You can download it here:
https://github.com/imincik/QgsPostGIS-Viewer
How to use it, look for __doc__ string at the very beginning of the file
or run it without any arguments.
Ivan Mincik, Gista s.r.o.
URL:
http://lists.osgeo.org/pipermail/qgis-user/attachments/20101114/720f5d14/attachment-0001.html
Message: 2
Date: Sun, 14 Nov 2010 18:50:06 +0100
Subject: Re: [Qgis-user] two little new plugins
To: M?ri Cedric <Cedric.Moeri at bd.so.ch>,    qgis-user
Message-ID: <4CE0214E.3000703 at gista.sk>
Content-Type: text/plain; charset=ISO-8859-1; format=flowed
On 11/14/2010 05:39 PM, Möri Cedric wrote:
> Hi list
> I just released two little plugins: traceDigitize and numericalDigitize. Both
>work on vector layers which are in edit mode.
> NumericalDigitize just opens a dialog with a table where you may enter
>x/y-values. After clicking ok, it will add a feature to your vectorlayer. The
>type of the feature is according to your layertype (point,line or polygon).
>  works only for line and polygon layers. It allows to digitize new features by
>following existing lines or polygon boundaries. The tool will add all vertex
>points, that are in snapping distance of the cursor. Just press ctrl key while
>moving the mouse. If control isn't pressed, it is just like the normal digitize
>tool. Don't forget to set the (background) snapping options, as the tool needs
>them.
Perfect, thanks a lot for sharing.
Message: 3
Date: Sun, 14 Nov 2010 19:20:23 +0100
To: qgis-user at lists.osgeo.org
Message-ID: <4CE02867.1090505 at faunalia.it>
Il 14/11/2010 17:39, Möri Cedric ha scritto:
> TraceDigitize works only for line and polygon layers. It allows to
> digitize new features by following existing lines or polygon
> boundaries. The tool will add all vertex points, that are in snapping
> distance of the cursor. Just press ctrl key while moving the mouse.
> If control isn't pressed, it is just like the normal digitize tool.
> needs them.
Quite nice. Beware though that it is very easy to generate invalid
geometries this way, and get a free crash as a consequence:
Error:
        GDAL Error 1: Attempt to read shape with feature id (-2) out of
available range.
Segmentation fault
Thanks a lot.
http://www.faunalia.it/pc
Message: 4
Date: Sun, 14 Nov 2010 12:41:39 -0800 (PST)
Subject: [Qgis-user] Re: qgis oracle connection
Message-ID: <1289767299610-5738215.post at n2.nabble.com>
Content-Type: text/plain; charset=us-ascii
https://trac.osgeo.org/qgis/ticket/2026#comment:2 says that the connection
should be fixed by now. (Is it about OGR for Oracle Spatial especially and
relates with Oracle (OCI) library, see http://www.gdal.org/ogr/ and
http://www.gdal.org/ogr/drv_oci.html?)
http://forum.qgis.org/viewtopic.php?f=2&t=6147 says that you can get the
OSGeo4W installer (online installer for windows - xp, vista, 7) from the
QGIS website http://www.qgis.org/wiki/Download#OSGeo4W_Installer. Run it and
choose "advanced installation". From desktop section choose qgis-dev. (From
GRASS, some package seems to come along that.) Then open that
...\download.osgeo.org%2fosgeo4w\release\qgis\qgis-devqgis-dev-1.7.0-4.tar.
There is at least the apps\qgis-dec\plugins\oracleplugin.dll file.
Any other ODBC or OGR related thing needed from there? How to use these -
just put the dll in some QGIS subfolder, or is there a need to compile? Is
the Oracle Spatial license always needed?
View this message in context:
http://osgeo-org.1803224.n2.nabble.com/qgis-oracle-connection-tp2038299p5738215.html
Sent from the qgis-user mailing list archive at Nabble.com.
Message: 5
Date: Sun, 14 Nov 2010 22:08:21 +0100
Subject: AW: [Qgis-user] two little new plugins
Message-ID:
    <1241553584.141289768901519.JavaMail.root at srsofaioi13477.ktso.ch>
Content-Type: text/plain;    charset="iso-8859-1"
Hi Paolo
you're right about the invalid geometries. I try to put a warning in the tool,
to tell you that there is problem in the geometry. Doing this I stumbeld over a
bug in the Rubberband class, so it will take some work to be done (hopefully by
Juergen). As there are other issues as well, I marked the plugin as experimental
for now.
regards
Cédric
mit freundlichen Grüssen
Cédric Möri
GIS-Informatiker
Kanton Solothurn
Bau- und Justizdepartement
Amt für Geoinformation
Rötistrasse 4
4501 Solothurn
Telefon: +41 (0)32 627 24 75
Telefax: +41 (0)32 627 22 14
mailto:cedric.moeri at bd.so.ch
http://www.agi.so.ch
----- Originalnachricht -----
Von: "Paolo Cavallini" <cavallini at faunalia.it>
Gesendet: Son, 14.11.2010 19:20
An: qgis-user at lists.osgeo.org
Betreff: Re: [Qgis-user] two little new plugins
> needs them.
Error:
available range.
Segmentation fault
Thanks a lot.
Qgis-user at lists.osgeo.org
Message: 6
Date: Sun, 14 Nov 2010 22:13:36 +0100
Subject: Re: AW: [Qgis-user] two little new plugins
Message-ID: <4CE05100.1040600 at faunalia.it>
Il 14/11/2010 22:08, Möri Cedric ha scritto:
> Hi Paolo
>for now.
Thanks for the prompt reaction.
Anyway, the problem is absolutely general: digitizing invalid geometries
is easy (perhaps a little easier with automatic digitizing like your
plugin), and currently crashes qgis rather easily.
So anything that prevents invalid geometries (or corrects them before
committing) is welcome, as it is some crash-prevention mechanism.
All the best.
Message: 7
Date: Sun, 14 Nov 2010 23:21:24 -0200
From: Rodrigo Moreira Maia <operigoso at ig.com.br>
Subject: [Qgis-user] help me isolines;;
Message-ID:
    <AANLkTi=kJ1WBmxRNRj+f8m7R1Lf=qMgaAxYqJq_EUr2U at mail.gmail.com>
Hi !! i need create isolines in qgis, using a shape file points..
tanks ..
URL:
http://lists.osgeo.org/pipermail/qgis-user/attachments/20101114/64d58f19/attachment-0001.html
Message: 8
Date: Sun, 14 Nov 2010 18:08:51 -0800
Subject: Re: [Qgis-user] help me isolines;;
Message-ID: <4CE09633.9040400 at wildintellect.com>
> tanks ..
Try the Contour python plugin. You will need to Fetch Python Plugins and
it also requires that you install the Shapely Python library.
Otherwise you can do this with the GRASS plugin. Though you might need
to 1st interpolate a raster from the point data and then convert
isolines with r.contour.
Enjoy,
Alex
Message: 9
Date: Sun, 14 Nov 2010 20:00:46 -0800 (PST)
    <kumaran.narayanaswamy at kcubeconsulting.com>
Subject: Re: [Qgis-user] using manageR
To: fgraz at unam.na, qgis-user at lists.osgeo.org,    Phil Morefield
    <philmorefield at yahoo.com>
Message-ID: <612773.66189.qm at web806.biz.mail.mud.yahoo.com>
Yeah R.exe should be in environment PATH variable.
Kumaran
Date: Saturday, November 13, 2010, 12:24 AM
Patrick-
This might be an issue with R 2.12. On my XP machine, prior version of R
installed the "R.exe", among other important files, here:
C:/Program Files/R/R-2.11.1/bin
When I install 2.12.0, the same files go here instead:
C:/Program Files/R/R-2.12.0/bin/i386
My guess is manageR is looking for "R.exe" in the old default path.
Hope that helps.
Phil
 Man brings all things to the test of himself, and this is notably true of
lightning.
-Aldo Leopold
Sent: Fri, November 12, 2010 7:15:21 AM
Subject: [Qgis-user] using manageR
Hi all,
I have tried to get manageR to work on a windows XP box (R2.12 & QGIS
1.5/1.6)but don't seem to have any luck. To the best of my knowledge I have
all the necessary extensions installed in R (ade4, aspace, sp, spgrass6,
rgdal) adehabitat and have rpy2 installed.
When I tried using QGIS 1.5 manageR would tell me that it could not find the
r212.dll (I didn't write that error msg down...) but at least it tried...
With 1.6 extension does not respond at all (i.e. you click on its icon and
nothing happens).
I have tried uninstalling and re-installing R and qgis
but it's still not
working. Where would I need to look to find out if my installation is
sufficiently complete - and should be working. Is there a compatibility
issue between the versions of the software - or software and extensions?
Another thought - when I upgraded from R2.10 to R2.12 on an Ubuntu machine I
could also not access manageR anymore...
Any help would be welcome.
Patrick
Dr. F. Patrick Graz
Snr. Researcher,
Multidisciplinary Research Centre,
University of Namibia
-----Inline Attachment Follows-----
URL:
http://lists.osgeo.org/pipermail/qgis-user/attachments/20101114/b0dd9d48/attachment.html
End of Qgis-user Digest, Vol 57, Issue 21
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20101115/05009a31/attachment.html>
