[Qgis-user] overview in the composer
MORREALE Jean Roc
jr.morreale at enoreth.net
Wed Nov 17 13:44:17 PST 2010
I think that what Dario has in mind is a map object of the canvas with a
different layer selection than his main map object which, if I'm
correct, is actually not possible dynamically in QGIS. What I usually do
is importing a raster of a previous composition to serve as the light
overview.
Regards,
Jean Roc
Le 17/11/2010 21:09, Giovanni Manghi a écrit :
> Hi Dario,
> in the composer you can add how many map object as you want, so you can
> add one that will serve as overview.
> cheers
> -- Giovanni --
> On Wed, 2010-11-17 at 11:50 -0800, Dario wrote:
>> how to display an overview map with locator on the composer printer?
