[Qgis-user] Qgis freezes with grass vector edit
Pablo Carreira pablotcarreira at hotmail.com
Thu Nov 18 04:40:10 PST 2010
Ticket #2429https://trac.osgeo.org/qgis/ticket/2429
May have something related to that...
Pablo Torres Carreira
To: qgis-user at lists.osgeo.org
Subject: RE: [Qgis-user] Qgis freezes with grass vector edit
Date: Thu, 18 Nov 2010 10:26:30 -0200
Hi Giovanni,> do the same happens if you edit the vectors directly into GRASS?> cheers> -- Giovanni --
This was happening when I was using PG as database. With DBF it doesn't happen anymore in GRASS, only in QGIS.
Below is the last 3 entries of the HIST file of the vector, the first one is the editing with grass,  the second with qgis, the third after I changed the grassdata dir name. The problem continues...
---------------------------------------------------------------------------------COMMAND: v.digit map="areas_medidas10 at petro"GISDBASE: c:\grassdata2LOCATION: utmwgs23 MAPSET: petro USER: A DATE: Thu Nov 18 10:08:29 2010---------------------------------------------------------------------------------COMMAND: QGISGISDBASE: C:/GRASSD~2LOCATION: utmwgs23 MAPSET: petro USER: A DATE: Thu Nov 18 10:11:09 2010--------------------------------------------------------------------------------COMMAND: QGISGISDBASE: C:/gsd2LOCATION: utmwgs23 MAPSET: petro USER: A DATE: Thu Nov 18 10:23:00 2010
Regards.
> Subject: Re: [Qgis-user] Qgis freezes with grass vector edit
> From: giovanni.manghi at gmail.com
> To: pablotcarreira at hotmail.com
> CC: qgis-user at lists.osgeo.org
> Date: Thu, 18 Nov 2010 11:44:03 +0000
> Hi Pablo,
> cheers
> -- Giovanni --
> On Thu, 2010-11-18 at 09:39 -0200, Pablo Carreira wrote:
> > Hi,
> > I'm experiencing a problem.
> > QGIS freezes when I edit GRASS vectors. It works for a while (just a
> > few clicks) then freezes.
> > It is something related to the database, I've reached this conclusion
> > because if I only move some vertices  there is no problem, but if I
> > delete something or query the database the problem occurs.
> > I've tried versions 1.5 and 1.6 from Osgeo4w.
> > I've tried PG, DBF and SQLITE as storage.
> > I've created new locations, mapsets and vectors.
> > Nothing solved the problem.
> > Some time ago, also with version 1.5, everything were working fine.
> > Could it be some bug of the newest builds?
> > Regards.
> > Qgis-user mailing list
> > Qgis-user at lists.osgeo.org
> > http://lists.osgeo.org/mailman/listinfo/qgis-user
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20101118/8f240e61/attachment.html>
