[Qgis-user] RE: [GRASS-user] grass plugin fail to render
ambrish dhaka ambijat at hotmail.com
Mon Nov 22 19:41:51 PST 2010
Thanks! Markus,
I found that gdal rpms are installed and the manage plugins windows also shows gdal tools therefore, this doesn't seem to be an issue. Also, when I try to select the project properties into UTM the workspace still remains on xy coordinate.
Ambrish
> From: neteler at osgeo.org
> Date: Mon, 22 Nov 2010 08:41:04 +0100
> Subject: Re: [GRASS-user] grass plugin fail to render
> To: ambijat at hotmail.com
> Hi Ambrish,
> (it would be better to keep this on the list to enable other to learn
> or help)
> moving stuff to a different Linux distro should not be an issue.
> But did you install the GDAL-GRASS plugin?
> Also: what is really the error message?
> Markus
> On Mon, Nov 22, 2010 at 4:27 AM, ambrish dhaka <ambijat at hotmail.com> wrote:
> > Hi! Markus,
> > It is the Grass 6.3 version and they are coming with the standard
> > installation repo.
> > But, real problem is that in standalone Grass the thing works fine. Or even
> > fetching them into Qgis is also good, but the opening raster from dataset in
> > Qgis is creating trouble.
> > One thing I did not mention is that I am moving this database from one
> > partition to another as I had previously created this dataset in Opensuse,
> > then I took it to a window partition and then after having Fedora 14
> > installed I brought this database back into home folder. Is that a possible
> > reason for this mess?
> > Thanks!
> > Ambrish
> >> Date: Sun, 21 Nov 2010 23:08:47 +0100
> >> CC: grass-user at lists.osgeo.org; qgis-user at lists.osgeo.org
> >> On Sun, Nov 21, 2010 at 4:26 PM, ambrish dhaka <ambijat at hotmail.com>
> >> wrote:
> >> > Dear All,
> >> > I face difficulty in rendering the raster data in grass data sets.
> >> > Though I
> >> > can directly import an image into qgis, it renders nice. But, with grass
> >> > plugins it is not happening. I am on Fedora 14 x86_64 platform.
> >> To my knowledge Fedora still serves GRASS 6.3 (but they started to
> >> produce 6.4 RPMs these days).
> >> Which version do you run? From Fedora or selfcompiled?
> >> Markus
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20101123/9f36d0e5/attachment.html>
