[Qgis-user] qgis 1.6 crashes
Giuseppe Sucameli sucameli at faunalia.it
Mon Nov 29 06:20:17 PST 2010
Hi Agustin,
On Mon, Nov 29, 2010 at 1:36 PM, Agustin Lobo <alobolistas at gmail.com> wrote:
> I think it is the gdal tools, as this is what I get on the console
> after the crash:
> Loaded : OpenStreetMap plugin (package: osm)
> Error:
>        GDAL Error 4: `/media/FREECOM_HDD/VGT/SM/untitled folder/subs.bil'
> does not exist in the file system,
> and is not recognised as a supported dataset name.
> Error: use of NULL environment is defunct
> During startup - There were 16 warnings (use warnings() to see them)
> *** stack smashing detected ***: /usr/bin/qgis.bin terminated
> Segmentation fault
I'm pretty sure that the crash is not due to GdalTools.
In fact GdalTools doesn't load anything since the user clicks on one of the
tools in
the Raster menu, instead seems that a plugin tries to load a .bil file from
an invalid
(maybe hard-coded) path...
The "GDAL Error" message is printed by the libgdal, not the GdalTools plugin
at all.
BTW, can you send us a list containing the installed plugins?
Cheers.
 gdaltools are not there when I start with qgis --noplugins
> but cannot uninstall it if I start normally,  as it comes now bundled,
> so I cannot fully test.
> Agus
> 2010/11/29 Agustin Lobo <alobolistas at gmail.com>:
> > Has to be that, as the crash does not occur if I start qgis with
> > qgis --noplugins
> > I'll ty to identify the offending plugin, any ideas?
> > Agus
> > 2010/11/29 Jürgen E. <jef at norbit.de>:
> >> Hi Agus,
> >> On Mon, 29. Nov 2010 at 12:12:50 +0100, Agustin Lobo wrote:
> >>> No crash for vector layers, crash for raster layers.
> >>> The test consists of:
> >>> 1. Open qgis and load a raster layer
> >>> 2. Save the project and close qgis
> >>> 3. move or rename the raster layer
> >>> 4. Open qgis and open the saved project
> >>> 5. Crash
> >> Do have anything "unusual" installed?  Like custom build GDAL and/or
> plugins
> >> other might not have?
> >> Jürgen
> >> Jürgen E. Fischer         norBIT GmbH               Tel.
> +49-4931-918175-20
> >> Dipl.-Inf. (FH)           Rheinstraße 13            Fax.
> +49-4931-918175-50
> >> Software Engineer         D-26506 Norden
> http://www.norbit.de
> >> norBIT Gesellschaft fuer Unternehmensberatung und Informationssysteme
> mbH
> >> Rheinstrasse 13, 26506 Norden
> >> GF: Jelto Buurman, HR: Amtsgericht Emden, HRB 5502
> >> _______________________________________________
> >> Qgis-user mailing list
> >> Qgis-user at lists.osgeo.org
> >> http://lists.osgeo.org/mailman/listinfo/qgis-user
Giuseppe Sucameli
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20101129/9dbf5bdc/attachment.html>
