AW: [Qgis-user] Re: WPS client plugin on ubuntu 10.04
Düster Horst
Horst.Duester at bd.so.ch
Tue Nov 30 03:03:31 PST 2010
Hi Michele
After you have loaded the capabilities of your WPS you have to select a
process and click OK. A GUI should appear depending on the inputs of the
process with all input options.
Horst
Dr. Horst Düster
Stv. Amtschef / kantonaler GIS-Koordinator
Kanton Solothurn
Bau- und Justizdepartement
Amt für Geoinformation
SO!GIS Koordination
Rötistrasse 4
CH-4501 Solothurn
Telefon ++41(0)32 627 25 32
Mobil ++41(0)79 511 54 12
Telefax ++41(0)32 627 22 14
mailto:horst.duester at bd.so.ch
http://www.agi.so.ch
-----Ursprüngliche Nachricht-----
Von: Michele Beneventi [mailto:mbeneventi at gmail.com]
Gesendet am: Dienstag, 30. November 2010 11:00
An: Jürgen E.; qgis-user at lists.osgeo.org
Betreff: [Qgis-user] Re: WPS client plugin on ubuntu 10.04
Hi Jürgen,
Thanks a lot.
Installing python-qt4-sql everything works fine.
Now I'm trying to connect to my geoserver WPS service. I am able to
connect and see the capabilities but nothing else: in the WPS plugin
form there is not place to sign the WFS layer name that I previously
catalogued as WFS layer (from postgis datastore) and load in the QGIS
ToC.
Is this procedure right?
Michele
On Tue, Nov 30, 2010 at 10:13 AM, Jürgen E. <jef at norbit.de> wrote:
> Hi Michele,
> On Tue, 30. Nov 2010 at 09:36:55 +0100, Michele Beneventi wrote:
>> I've already installed "libqt4-sql" without problem as you advise me,
>> but never is changed.
> Did you also install python-qt4-sql?
> Jürgen
> Jürgen E. Fischer norBIT GmbH Tel.
+49-4931-918175-20
> Dipl.-Inf. (FH) Rheinstraße 13 Fax.
+49-4931-918175-50
> Software Engineer D-26506 Norden
http://www.norbit.de
> norBIT Gesellschaft fuer Unternehmensberatung und Informationssysteme
mbH
> Rheinstrasse 13, 26506 Norden
> GF: Jelto Buurman, HR: Amtsgericht Emden, HRB 5502
> Qgis-user mailing list
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20101130/f2353406/attachment.html>
