[Qgis-user] Re: Qgis-user Digest, Vol 57, Issue 56
Kurt Springs ferret_bard at mac.com
Tue Nov 30 06:55:19 PST 2010
I was able to fix the problem by revealing the invisible files and deleting ~/.qgis/python/plugin, on the advise of William Kyngesburye.  It worked brilliantly.
Thanks all
Kurt
On Nov 30, 2010, at 5:00 AM, qgis-user-request at lists.osgeo.org wrote:
> Message: 2
> Date: Tue, 30 Nov 2010 09:52:06 +0100
> From: Anne Ghisla <a.ghisla at gmail.com>
> Subject: Re: [Qgis-user] Qgis crash on start up under OS X
> To: qgis-user at lists.osgeo.org
> Message-ID: <1291107126.2300.11.camel at galadriel.localdomain>
> Content-Type: text/plain; charset="utf-8"
> On Tue, 2010-11-30 at 09:37 +0100, Anne Ghisla wrote:
>> On Mon, 2010-11-29 at 18:31 -0600, William Kyngesburye wrote:
>>> See if you have a crashlog for QGIS.  Check Console.app and look in ~/Library/Logs/CrashReporter.
>>> On Nov 29, 2010, at 4:20 PM, Kurt Springs wrote:
>>>> Hi
>>>> I just installed Qgis 1.6 on my mac and it is crashing on start up.  Qgis 1.5 was working fine.  I have been getting this message on start up:
>>>> Unable to load the plugin: Unable to load required package rpy2.
>>>> Please ensure that both R, and the corresponding version of Rpy2 are correctly installed.
>> Hi Kurt, all,
>> this error message is likely raised by HomeRange_plugin.
>> You can start qgis with all plugins disabled
>> qgis --noplugins
>> (see qgis --help for more options)
>> and then, in the plugin manager, disable HomeRange plugin.
> correction: it is already disabled.
> Try to re-enable it and see if restarting qgis reproduces the crash.
> If so, either uninstall the plugin, either ...
>> ... install/upgrade rpy2 according to
>> your R version. Another plugin that needs R is manageR, usually if one
>> works, the other works too.
> cheers
> Anne
>>>> But I was getting this with 1.5 as well.
>>>> I tried it on my laptop where I don't get the message, and it is still quitting on startup.
>>>> Any idea what's wrong, and how to correct it?
>>>> Thanks
>>>> Kurt
>>>> _______________________________________________
>>>> Qgis-user mailing list
>>>> Qgis-user at lists.osgeo.org
>>>> http://lists.osgeo.org/mailman/listinfo/qgis-user
>>> William Kyngesburye <kyngchaos*at*kyngchaos*dot*com>
>>> http://www.kyngchaos.com/
>>> First Pogril: Why is life like sticking your head in a bucket filled with hyena offal?
>>> Second Pogril: I don't know.  Why IS life like sticking your head in a bucket filled with hyena offal?
>>> First Pogril: I don't know either.  Wretched, isn't it?
>>> -HitchHiker's Guide to the Galaxy
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20101130/6702181c/attachment.html>
