A+ GPS Recorder, i-Blue GPS 747 A+, Linux (Re: [Qgis-user] GPS tracking tool)
Werner Macho
werner.macho at gmail.com
Tue Nov 30 23:35:55 PST 2010
Hi!
AFAIK the patch is already applied by jef .. in #14772
But yes - it is generally a good idea to post bugs and patches in the
tracker ..
regards
Werner
Am 01.12.2010 05:12, schrieb John C. Tull:
> Hi Knut,
> You should post your problem and fix to the bug tracker. The developers are more likely to find your solution and patch qgis accordingly. You can find the tracker at http://trac.osgeo.org/qgis
> Regards,
> John
> On Nov 26, 2010, at 10:11 AM, Knut Sübert wrote:
>> Am 24.11.2010 schrieb "John C. Tull" <jctull at gmail.com>:
>>> There are also units without displays if you won't be needing that.
>> I tried the "A+ GPS Recorder", which seems similar to the "i-Blue GPS
>> 747 A+". A nice little box.
>> Connected by USB to Linux, the "A+" version appears as unusual named
>> device "/dev/ttyACM0". So a very small patch is needed for the tracking
>> tool:
>> --- src/core/gps/qgsgpsdetector.cpp (revision 14518)
>> +++ src/core/gps/qgsgpsdetector.cpp (working copy)
>> @@ -35,7 +35,7 @@
>> #ifdef linux
>> // look for linux serial devices
>> - foreach( QString linuxDev, QStringList() << "/dev/ttyS%1" << "/dev/ttyUSB%1" << "/dev/rfcomm%1" )
>> + foreach( QString linuxDev, QStringList() << "/dev/ttyS%1" << "/dev/ttyUSB%1" << "/dev/rfcomm%1" << "/dev/ttyACM%1" )
>> for ( int i = 0; i < 10; ++i )
> Qgis-user mailing list
