AW: [Qgis-user] two little new plugins
Möri Cedric
Cedric.Moeri at bd.so.ch
Sun Nov 14 16:08:21 EST 2010
Hi Paolo
you're right about the invalid geometries. I try to put a warning in the tool, to tell you that there is problem in the geometry. Doing this I stumbeld over a bug in the Rubberband class, so it will take some work to be done (hopefully by Juergen). As there are other issues as well, I marked the plugin as experimental for now.
regards
Cédric
mit freundlichen Grüssen
Cédric Möri
GIS-Informatiker
Kanton Solothurn
Bau- und Justizdepartement
Amt für Geoinformation
Rötistrasse 4
4501 Solothurn
Telefon: +41 (0)32 627 24 75
Telefax: +41 (0)32 627 22 14
mailto:cedric.moeri at bd.so.ch
http://www.agi.so.ch
----- Originalnachricht -----
Von: "Paolo Cavallini" <cavallini at faunalia.it>
Gesendet: Son, 14.11.2010 19:20
An: qgis-user at lists.osgeo.org
Betreff: Re: [Qgis-user] two little new plugins
Il 14/11/2010 17:39, Möri Cedric ha scritto:
> TraceDigitize works only for line and polygon layers. It allows to
> digitize new features by following existing lines or polygon
> boundaries. The tool will add all vertex points, that are in snapping
> distance of the cursor. Just press ctrl key while moving the mouse.
> If control isn't pressed, it is just like the normal digitize tool.
> Don't forget to set the (background) snapping options, as the tool
> needs them.
Quite nice. Beware though that it is very easy to generate invalid
geometries this way, and get a free crash as a consequence:
Error:
GDAL Error 1: Attempt to read shape with feature id (-2) out of
available range.
Segmentation fault
Thanks a lot.
http://www.faunalia.it/pc
Qgis-user mailing list
Qgis-user at lists.osgeo.org
http://lists.osgeo.org/mailman/listinfo/qgis-user
